Controlling ceiling LED panels
Yeah, one psu is fine, but i was searching for some replacement with two outputs, like the one in this particular panel, but which could be driven via some external dimmer for example and i could not find one.
So you are basically telling me, i can drive it like this?
Replacing the 36V LED controller in a LED panel - #4 by lukastillmann?
It will convert it to PWM driver, i guess. I thought, that this LED panels use voltage regulation, current stays constant
