Yes, I can switch all modes, also Standby/DHW/DHW & Heating modes as well. Which is not available in HA climate entity but has to be controlled by additional select entity (partially mapped to standard climate entity).
Pay attention to the number of parameters you monitor in HA - too many will require infrequent updates as the optolink interface is not very fast.
Here is my up to date config:
listhor
(M)
November 23, 2024, 3:58pm
42
Thanks for such a prompt reply.
As I have in hand Wemos D1 (ESP8266) and I’m new to esphome, do I need to change in esp config something more than rx/tx pins assignment?
HA config - will it be imported upon configuring esp device?
I recommend to go with esp32 as 8266 has limited resources, unless you just want to try it with only a few sensors.
HA will automatically import it
listhor
(M)
November 23, 2024, 6:19pm
45
Thanks for clarification!
listhor
(M)
November 30, 2024, 12:08pm
46
Hi again @adorobis
Question about commented out sections in your config. Are those working configs (exhaust or return temperatures) but not needed in your use case?
And also I don’t see below code as well:
text_sensor:
- platform: optolink
name: Error history 1
address: 0x7590
bytes: 9
type: RAW
name: Heating schedule Monday
type: DAY_SCHEDULE
day_of_week: MONDAY
address: 0x2000
bytes: 56
It’s missing to reduce number of datapoints?
No, in my case they are duplicating info from other sensors.
This one works ok, I keep only last two errors - good enough for me. But I configured it with mapping to error description:
name: Error code 1
address: 0x7507
bytes: 1
update_interval: 591s
icon: mdi:note-text-outline
type: MAP
filters:
- map:
- "0 -> regular operation"
- "15 -> 0 F : Przeprowadzić konserwację. Po konserwacji ustawić kodowanie 24:0"
- "16 -> 1 0 : Zwarcie czujnika temperatury zewnętrznej"
- "231 -> E 7 : Usterka palnika"
- "232 -> E 8 : Usterka palnika"
- "238 -> E E : Blokada palnika"
I don’t use this one. I have not really found good use to replicate it in HA.
listhor
(M)
December 9, 2024, 2:03pm
48
I have configured esp32-s3.
My config is as follows:
substitutions:
device_name: viessmann
device_description: "Viessmann Optolink"
update_interval_global: 60s
update_interval_short: 15s
update_interval_long: 600s
esphome:
friendly_name: Viessmann
project:
version: "1.0"
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
flash_size: 16MB
# Enable logging
logger:
hardware_uart: UART0
baud_rate: 0
level: debug
# Enable Home Assistant API
api:
encryption:
key: "xxx"
ota:
- platform: esphome
password: "xxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Viessmann Fallback Hotspot"
password: "xxx"
captive_portal:
dashboard_import:
package_import_url: github://esphome/firmware/esphome-web/esp32s3.yaml@main
import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
authorizer: none
# To have a "next url" for improv serial
web_server:
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
external_components:
- source: github://pr#4453
components: [ optolink ]
optolink:
protocol: KW
# device_info: Device Info
# state: Component state
rx_pin: 44
tx_pin: 43
button:
- platform: restart
text_sensor:
- platform: version
hide_timestamp: true
- platform: wifi_info
ip_address:
icon: mdi:wifi
ssid:
icon: mdi:wifi-strength-2
type: DEVICE_INFO
update_interval: 969s
type: STATE_INFO
update_interval: 459s
name: Current Operating Mode A1
address: 0x2500
bytes: 2
update_interval: 128s
type: MAP
filters:
- map:
- "2 -> off" # when in standby or dhw modes
- "258 -> reduced" # when in reduced (night) or forcedReduced modes or in Eco preset
- "514 -> comfort" # when in day heating or in Comfort preset
- "770 -> normal" # when in forcedNormal type
name: Current Operating Mode M2
address: 0x3500
bytes: 2
update_interval: 130s
type: MAP
filters:
- map:
- "2 -> off"
- "258 -> reduced"
- "514 -> comfort"
- "770 -> normal"
# - platform: optolink
# name: Error history 1
# address: 0x7590
# bytes: 9
# type: RAW
# above disabled for last two errors configured with mapping to error description
# errors : 0:7507, 1:7510, 2:7519, 3:7522, 4:752B, 5:7534, 6:753D, 7:7546, 8:754F, 9:7558
name: Error code 1
address: 0x7507
bytes: 1
type: MAP
filters:
- map:
name: Error code 2
address: 0x7510
bytes: 1
update_interval: 589s
type: MAP
filters:
- map:
# name: Error code 3
# address: 0x7519
# bytes: 1
# update_interval: 587s
# icon: mdi:note-text-outline
# filters:
# - map:
# - "0 -> regular operation"
# - "15 -> 0 F : Przeprowadzić konserwację. Po konserwacji ustawić kodowanie 24:0"
# - "16 -> 1 0 : Zwarcie czujnika temperatury zewnętrznej"
# - "231 -> E 7 : Usterka palnika"
# - "232 -> E 8 : Usterka palnika"
# - "238 -> E E : Blokada palnika"
binary_sensor:
address: 0x55D3
update_interval: 52s
device_class: heat
address: 0x650A
update_interval: 50s
device_class: heat
# name: Storage Charging Pump
# address: 0x6513
# update_interval: 52s
# device_class: power
address: 0x6515
update_interval: 54s
device_class: power
name: Heating circuit pump A1M1
address: 0x2906
update_interval: 56s
device_class: power
name: Heating circuit pump M2
address: 0x3906
update_interval: 64s
device_class: power
name: Frost protection
address: 0x27A4
update_interval: 593s
device_class: cold
number:
# name: Time limit party and operating mode switching
# address: 0x27F2
# bytes: 1
# min_value: 0
# max_value: 100
# step: 1
# type: box
# update_interval: 595s
name: Room Temperature Setpoint
unit_of_measurement: °C
address: 0x2306
bytes: 1
min_value: 18
max_value: 27
step: 1
icon: "mdi:home-thermometer"
device_class: temperature
update_interval: 315s
name: Reduced Room Temperature Setpoint
address: 0x2307
bytes: 1
min_value: 10
max_value: 20
step: 1
update_interval: 597s
name: Party Temperature Setpoint
address: 0x2308
bytes: 1
min_value: 18
max_value: 27
step: 1
update_interval: 599s
name: Floor Temperature Setpoint
address: 0x3306
bytes: 1
min_value: 18
max_value: 27
step: 1
update_interval: 280s
name: Reduced Floor Temperature Setpoint
address: 0x3307
bytes: 1
min_value: 10
max_value: 20
step: 1
name: Party Floor Temperature Setpoint
address: 0x3308
bytes: 1
min_value: 18
max_value: 27
step: 1
name: Heating curve level
address: 0x27D4
bytes: 1
min_value: 0
max_value: 10
step: 1
mode: box
update_interval: 601s
name: Heating curve slope
address: 0x27D3
bytes: 1
min_value: 0
max_value: 3
step: 0.1
mode: box
div_ratio: 10
update_interval: 603s
name: Floor Heating curve level
address: 0x37D4
bytes: 1
min_value: 0
max_value: 10
step: 1
mode: box
update_interval: ${update_interval_long}
name: Floor Heating curve slope
address: 0x37D3
bytes: 1
min_value: 0
max_value: 3
step: 0.1
mode: box
div_ratio: 10
update_interval: 607s
name: DHW Temperature Setpoint
address: 0x6300
bytes: 1
min_value: 30
max_value: 60
step: 1
icon: "mdi:water-boiler"
update_interval: 605s
- platform: wifi_signal
update_interval: ${update_interval_global}
type: QUEUE_SIZE
name: Optolink Queue Size
icon: mdi:queue-first-in-last-out
entity_category: diagnostic
update_interval: 5s
name: Target flow temperature A1M1
address: 0x2544
bytes: 2
div_ratio: 10
accuracy_decimals: 1
update_interval: 330s
state_class: measurement
force_update: true
name: Target flow temperature M2
address: 0x3544
bytes: 2
div_ratio: 10
update_interval: 332s
force_update: true
# Enabled for test
name: Return temperature
address: 0x0816
bytes: 2
div_ratio: 1
filters:
multiply: 0.1
update_interval: 62s
force_update: true
name: Flow temperature M2
address: 0x3900
bytes: 2
div_ratio: 1
filters:
multiply: 0.1
update_interval: 48s
force_update: true
# Enabled for test
name: Exhaust temperature
address: 0x0808
bytes: 2
div_ratio: 1
filters:
multiply: 0.1
update_interval: 68s
force_update: true
name: Storage temperature
address: 0x0812
bytes: 2
div_ratio: 1
filters:
multiply: 0.1
update_interval: 175s
force_update: true
name: Outside Temperature
address: 0x0800
#address: 0x5527
bytes: 2
div_ratio: 10
update_interval: 611s
force_update: true
name: Boiler Temperature
address: 0x0802
bytes: 2
div_ratio: 10
update_interval: 28s
force_update: true
name: Room temperature
address: 0x0896
bytes: 2
div_ratio: 1
filters:
multiply: 0.1
force_update: true
address: 0x08A7
bytes: 4
device_class: duration
unit_of_measurement: h
state_class: total_increasing
icon: mdi:counter
update_interval: 909s
filters:
- lambda: return x / 3600;
force_update: true
address: 0x088A
bytes: 4
update_interval: 911s
icon: mdi:counter
force_update: true
name: Burner Performance
address: 0xA38F
bytes: 1
filters:
multiply: 0.5
update_interval: ${update_interval_short}
unit_of_measurement: "%"
icon: mdi:percent
force_update: true
select:
address: 0x2323
bytes: 1
map:
- "0 -> standby"
- "1 -> dhw"
- "2 -> dhwAndHeating"
- "3 -> forcedReduced"
- "4 -> forcedNormal"
name: Operation mode M2
address: 0x3323
bytes: 1
map:
- "0 -> standby"
- "1 -> dhw"
update_interval: 123s
update_interval: 10s
options:
- "off"
- "eco"
- "comfort"
set_action:
- lambda: |-
if (x == "off") {
id(economy_mode).turn_off();
id(party_mode).turn_off();
} else if (x == "eco"){
id(economy_mode).turn_on();
} else if (x == "comfort"){
id(party_mode).turn_on();
lambda: !lambda |-
if (not(id(economy_mode).state) and not(id(party_mode).state)) {
return (std::string) "off";
} else if (id(economy_mode).state) {
return (std::string) "eco";
} else if (id(party_mode).state) {
return (std::string) "comfort";
} else {
options:
- "off"
- "eco"
- "comfort"
set_action:
- lambda: |-
if (x == "off") {
id(economy_mode_m2).turn_off();
id(party_mode_m2).turn_off();
id(economy_mode_m2).turn_on();
id(party_mode_m2).turn_on();
lambda: !lambda |-
if (not(id(economy_mode_m2).state) and not(id(party_mode_m2).state)) {
} else if (id(economy_mode_m2).state) {
} else if (id(party_mode_m2).state) {
} else {
switch:
address: 0x2302
icon: mdi:sprout-outline
address: 0x2303
icon: mdi:glass-cocktail
update_interval: 72s
name: Economy mode M2
address: 0x3302
update_interval: 303s
name: Party mode M2
address: 0x3303
update_interval: 307s
I’m not so sure about leaving BLE enabled but I don’t think it will make any harm?
Portal works as well:
Other thing is numbering of rx, tx pins. As per:
I set:
rx_pin: 44
tx_pin: 43
Is it correct?
But main question is: does optolink software contain any presets and may change settings of viessmann heater upon connecting this device?
listhor:
I set:
rx_pin: 44
tx_pin: 43
Is it correct?
Yes, that should be correct.
No, it does not send any config/parameter change commands upon connecting. You have to send them explicitly.
listhor
(M)
December 9, 2024, 4:19pm
50
Once again big thanks! And I’m in shock - first attempt and it works:
The only thing I’m not so sure of, are these errors:
I don’t see them displayed on heater’s display plus temperature readings are ok and do correspond to other outdoor temperature sensors readings…
So, is mapping wrong or it is an “old” - inactive error?
EDIT:
Presets: Eco and comfort, what do they set and how can verify/edit those settings being changed?
Those could be old errors. Check the device manual - there is an option to go through the history of errors. It will also have mapping from the hex code to what it actually means.
Eco is switching the heater to the reduced temp. mode - it stays this way until next scheduled time
Comfort - the other way round - switches to normal temp mode until the next scheduled time.
You can see and control them on the room or heater controller - depending on which version you have
listhor
(M)
December 9, 2024, 4:44pm
52
It is getting more clear, thanks again!
One, last question: “Optolink Queue Size” - it shows values between 70 and 80. Is it ok or it means update intervals issue?
EDIT:
Maybe one more question: When I switch party mode on in heater’s controller (locally) - it changes status of party mode switch (in HA) to “on” and preset to “comfort”.
Other way around, switching party mode on in HA, it toggles preset to “comfort” as well but I don’t see status changed in heater’s controller - party mode indicator LED remains unlit… Is it as expected?
That is most likely representing an issue. You have too many entities being updated too frequently.
This in my opinion also most likely impacts your attempt to control the party mode as requests are not getting processed or it takes long time before they are.
Try to increase the update interval so that the queue size does not exceed 10 at any time.
You can also increase update interval of some entities to very high values for entities that don’t change at all like the heating curve etc.
yuanyuan
(yuan)
December 16, 2024, 1:32pm
54
Hello, I also have the same model of boiler as Viessmann, but today I used an OT device to connect it and found that I could only read the data of the hot water and could not perform any control. I read the instructions and found that there is a jumper between L and 1 that needs to be remove, but I checked and found that my boiler does not have this jumper. Does your boiler have it? How did you connect it?
Other Viessmann boilers need to be set to OT mode in the menu after connecting to the OT device. Ours does not have a menu, do we need to set it?
listhor
(M)
December 18, 2024, 6:05pm
55
Unfortunately, it seems like I’m not able to change/activate Party Mode via optolink. After toggling any of switches:
switch:
address: 0x2302
address: 0x2303
address: 0x3302
name: Party mode M2
address: 0x3303
They change (temporarily) its own presets and after several seconds all goes back to previous state (I guess once values are read again).
There is a post: Viessmann OpenV vcontrold Client (Optolink) - #62 by pashdown saying that setting new values doesn’t work…
@adorobis does it work on your side? And if so, did you need to change anything else in boiler/heater?
Yes, party and eco modes work for my heater, even on both circuits (main and the floor heating). I did not have to change anything in config or in any other place as far as I remember. The only thing is that it takes sometimes even 2-3 minutes before the eco or party mode is really activated.
listhor
(M)
December 18, 2024, 9:45pm
57
I know it’s a bit wild guess but I’ve just found page: OpenV_NodeMCU/VitoWifi_NodeMCU.ino at 12eca651bbfbc7485fad270e2ef1afbed0b84d6f · Schnup89/OpenV_NodeMCU · GitHub
with following code:
//###### Betriebsarten
DPMode getBetriebArtM1("getbetriebartm1","betriebsarten", 0x2301); //HK1 0=Abschaltb,1=nur WW,2=heiz+WW, 3=DauernRed,3=Dauer Norma.
DPMode getBetriebArtM2("getbetriebartm2","betriebsarten", 0x3301); //HK2 0=Abschaltb,1=nur WW,2=heiz+WW, 3=DauernRed,3=Dauer Norma.
DPStat getBetriebPartyM1("getbetriebpartym1","betriebsarten", 0x2303); //HK1 Party
DPStat getBetriebPartyM2("getbetriebpartym2","betriebsarten", 0x3303); //HK2 Party
DPStat setBetriebPartyM1("setbetriebpartym1","betriebsarten", 0x2330); //HK1 Party schreiben
DPStat setBetriebPartyM2("setbetriebpartym2","betriebsarten", 0x3330); //HK2 Party schreiben
Above shows that addresses configured in my setup:
0x2303
0x3303
are used to retrieve party mode status…
I can’t find list of optolink functions addresses, can anybody confirm them?
Those addresses are used both for reading and setting the state. And that’s how it is done in the optolink integration as well with the switch entities:
switch:
address: 0x2302
address: 0x2303
listhor
(M)
December 19, 2024, 10:17am
59
Would have been safe enough to try for setting party mode these addresses:
0x2330
0x3330
instead of already in use:
0x2303
0x3303
listhor
(M)
December 21, 2024, 8:12pm
60
Ok, If I change party mode switches’ addresses to:
0x2330
0x3330
they remain constantly ON.
when set as:
0x2303
0x3303
switches are OFF.
If I toggle them, they switch themselves back respectively, to their initial status.
On the other hand, Current Operating Mode A1 value is “773” . Nothing of configured mapping:
address: 0x2500
bytes: 2
type: MAP
filters:
- map:
What is the meaning of “773” status? If I’m not mistaken, my hardware configuration is that M1 heats up boiler (water heat accumulator) with secondary loops’ coils inside.
And M2 is those secondary loops…
Current Operating Mode M2 keeps showing “comfort”
Thus, is there any way to get Party Mode switches functioning?
