So, I am trying the above timeticks conversion and am getting nowhere… I have my sensor configs in a sensors directory with files per device under that. This works and has worked for ages. But, when I put the below code in my mikrotik sensors file and run a configuration check it just sits and spins until I cut the code out and check it again… What have I done wrong? I have included the snmp sensor that sources the data and works fine.
- platform: snmp
unique_id: mt610uptime
host: 192.168.1.9
community: homeread
baseoid: .1.3.6.1.2.1.1.3.0
accept_errors: true
sensors:
mt610_real_uptime:
friendly_name: Mt610 Real Uptime
value_template: >-
{% set time = states.sensor.mt610_uptime.state | int %}
{% set minutes = ((time % 360000) / 6000) | int%}
{% set hours = ((time % 8640000) / 360000) | int %}
{% set days = (time / 8640000) | int %}
{%- if time < 6000 -%}
Less than a minute
{%- else -%}
{%- if days > 0 -%}
{%- if days == 1 -%}
1 day
{%- else -%}
{{ days }} days
{%- endif -%}
{%- endif -%}
{%- if hours > 0 -%}
{%- if days > 0 -%}
{%- endif -%}
{%- if hours == 1 -%}
1 hour
{%- else -%}
{{ hours }} hours
{%- endif -%}
{%- endif -%}
{%- if minutes > 0 -%}
{%- if days > 0 or hours > 0 -%}
{%- endif -%}
{%- if minutes == 1 -%}
1 minute
{%- else -%}
{{ minutes }} minutes
{%- endif -%}
{%- endif -%}
{%- endif -%}
