Can this be used without Hassio and just Home Assistant?
If you only use HomeAssistant without HassIO, please follow the guide in the first post.
So, iāve everything up and running! Thanks for the tutorial! Once I got HomeGear running, it worked like a charm.
There are two things Iām working on right now, maybe someone has a hint:
I have rooms with two radiator thermostats. How can I make HomeAssistant automatically set the temperature of the first thermostat, if I change it manually for the second?Solved, see Converting a MAX! Cube to CUL/CUN to use with Home Assistant -
Seems like my MAX! Eco Taster does not pair. Someone experiencing the same?Worked after resetting the Eco Taster.
Great so glad to hear you got it all working.
For adjusting the thermostats, what do you use for automations? - built in HA automations or Node Red?
It would be extremely simple with Node Redā¦ But I donāt have experience of built in HA automations much, so not sure on that front.
I just finished up connecting a flow that turns on the heating when at least 2 room are > 1 degree less than the Max! Setpoint for that room.
Once I have the kinks ironed out Iāll post it here.
Iāve mentioned this in the OP for anyone arriving and wanting to try this out.
Thanks for your efforts
Currently Iām only using build-in automation. I will have a look at Node Red tomorrow, I havenāt tried it yet. If youāve an idea how to quick-solve this problem, Iād be very happy
I think using built in automation, you need something like;
- alias: 'Match Thermostats'
platform: state
entity_id: climate.def54321
service: climate.set_temperature
data_template:
entity_id: climate.abc12345
value: {% state_attr('climate.def54321', 'temperature') %}
I believe this should set device climate.abc12345 to the value of climate.def54321 when it changesā¦ But Iāve not tested as Iām not using built in automation.
like this the automation triggers with a change in state (def)?
Yes - Iād think so (as I say, Iāve not tested), but from what I can tell looking at the automation docs - that should push the temperature value of ādefā to āabcā each time the state of ādefā is changed.
Well, i will give it a try.
On the first view i think that influxdb and node-blue is not nessacery in the container and i am also not shure if the /var/lib/homegear directory must also be published to outside of the container.
Greetings from germany
Ludger
The /var/lib/homegear is stored outside the container, but not visible for the user. It is stored in /data, this is the default directory for persistent data for HassIO addons. Is there a reason to make it user editable / visible?
To be honest, I have no idea what influxdb is used for, but it is part of the official homegear docker container. Can you explain what this is used for?
I havenāt used Homegear in a while, but the resolvenames: json
setting is targeted at people that use the HomeMatic CCU2/3, which exposes a JSON-RPC API. When I was using Homegear it did not have the JSON-RPC API like the CCU.
It should be possible though to set this to resolvenames: metadata
(and remove username + password), which then would use the names you set within you manager software (that type of software stores the names in the metadata).
In my case, the problem starts earlier. When entering names in Homematic Manager, they arenāt even stored in homegear. The names are not displayed on the status website of homegear, neither are they displayed in a second instance of Homematic manager in a different machine.
Thanks for the tip - Iāll try the metadata option out
If you can verify my statement please consider updating your inital post. From a technical perspective (Homegear from 2017) resolvenames
is a non-functional configuration in terms of resolving names.
Thanks for sharing this and your awesome guide! I have ordered, had delivered, flashed and setup a cube and X1 radiator valve since your first post. Iām also using HomeGear natively on a Linux server.
Seems to be working well so far, looking forward to testing it over the coming weeks.
Out of interest what are you using to control your boiler?
Thanks again for sharing!!
Glad it was of use
Iām using a Shelly 1 flashed with Tasmota firmware to control my boiler - the relay on the shell closes the thermostat circuit on the boiler so that it knows heat is required.
I then just set my traditional timeclock to āONā 24/7 - since the boiler only fires when the shelly circuit closes.
Awesome, thank you.
Do you know if these can be exposed to HA? https://www.eq-3.com/products/max/max-house-solution/max-wall-thermostat.html
Do you know if they will still update the current temperature of the radiator valves with the temperature of the wireless wall thermostat? Or does the firmware break that link?
Yes, the wall thermostat should pair OK with homegear.
I have the same unit, but itās sat in a drawer now, since I just use HA to adjust the setpoints instead.
Iād suspect that the wall thermostat wouldnāt update the radiator valves by default with the new firmware, but you could easily get it working using automations or node red.
ie. when wall thermostat changed, set radiator x, y and z to the wall thermostat value.
I meant update the ācurrentā temp to the sensor value in the wall unit. Can you update the ācurrentā temp of the radiator valve as well as target temp?
