Core-2021.5.0 broken MSSQL connection
Hi
The documentation on the Recorder has been updated.
Working connection string. It is formatted just like an URL. (no semicolons or curly brackets)
mssql+pyodbc://username:password@SERVER_IP:1433/DB_NAME?charset=utf8mb4&driver=FreeTDS
I was forced to recreate database due to date conversion as mentioned above.
I tried this but it didnā€™t help me.
2021-05-13 12:02:31 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup to mssql+pyodbc://username:password@serverip:1433/homeassistant?charset=utf8mb4;driver=FreeTDS: (pyodbc.InterfaceError) ('IM002', '[IM002] [unixODBC][Driver Manager]Data source name not found and no default driver specified (0) (SQLDriverConnect)')
Re-creating the database you lose your history right ;o? hmmm Iā€™ll wait for another solution than.
Hey guys, Is there an open issue on GitHub for this one?
i change the DB link now i get a migration fail ā€¦ i dont know how to do the steps from burken
can anyone help please ?
MSSQL not working once again. It seems to be not working more often than it works.
This worked for me. Thank you!
again with the 2021.6 what changed this time ?
Does someone know how the database should look like so it works? If I just try to manually do the required changes. Schema_changes table and all.
Yup, brokenā€¦
2021-06-02 22:01:13 WARNING (Recorder) [homeassistant.components.recorder.migration] Database is about to upgrade. Schema version: 14
2021-06-02 22:01:13 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: 'options'
2021-06-02 22:01:13 ERROR (Recorder) [homeassistant.components.recorder] Error during schema migration
  File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 683, in _migrate_schema_and_setup_run
    migration.migrate_schema(self, current_version)
  File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 64, in migrate_schema
    _apply_update(instance.engine, session, new_version, current_version)
  File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 452, in _apply_update
    _drop_foreign_key_constraints(
  File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 322, in _drop_foreign_key_constraints
    and foreign_key["options"].get("ondelete")
KeyError: 'options'
Seems to be because of this Oracle DB support which requires schema version change to 16.
Works for me after I commented out this part of the code:
Well thanks for the info but i dont know how to do that :laughing:
We currently donā€™t have a core developer that uses MSSQL so it doesnā€™t get active testing: Recorder - Home Assistant
This PR likely fixes it Handle missing options in foreign_key for MSSQL by bdraco Ā· Pull Request #51503 Ā· home-assistant/core Ā· GitHub
