Core.entity_registry prevents home-assistant from starting
It is not an esp01, it is an AC by daikin so there’s no settings to modify.
I don’t know about that Daikin AC integration.
Maybe it should be adapted for the latest release of HA.
You can always open a ticket for that.
In the mean time, either go back to previous version of HA or disable the Daikin AC integration.
Unless someone else has a better idea?
It’s not the core Daikin integration, it does not use the ESPHome API.
They may have an ESPHome IR remote that controls their Daikin A/C?
That’s also what I thought when I saw the
but now I’m confused by
Yeah totally confusing. The core Daikin integration uses this: pydaikin · PyPI
This is what it looks like from the entity registry : IR Remote Climate — ESPHome
Though even then, in the entity registry it is only a temperature sensor, not a climate device.
I think I just had a stroke :'D
So, lets sumarize, shall we:
  1. The core.entity_registry contains an invalid character, a “?C” that should be a “°C”
  2. Correcting the file is useless as next HA restart is bringing back that “?C”
  3. Identifying the source of that corruption seems impossible as
    3.1 The core.entity_registry file seems to indicate that it was created by an ESPHome sensor
    3.2 But it is not an esp01, it is a Daikin AC sensor
    3.3 But it is not coming from the Daikin AC integration
Wow!
From what *** file can this entity come? (I’m censoring myself)
My guess is some sort of ESPHome based ir remote that controls the AC.
Sorry everyone for the delay. The integration is the core Daikin integration.
In any case, i noticed that this error occurs also in one of my z-wave based temperature sensor:
        "config_entry_id": "645f5c225c839ffac1d4fa6d81c15fd5",
        "device_class": null,
        "device_id": "0b6af9320e8b4a1aaf8fc5a447fb4c2f",
        "disabled_by": null,
        "entity_category": null,
        "entity_id": "sensor.living_room_temperature",
        "hidden_by": null,
        "icon": null,
        "id": "9e3e59afe0ed0dd28805cdd796af3639",
        "has_entity_name": false,
        "name": null,
        "options": {},
        "original_device_class": "temperature",
        "original_icon": null,
        "original_name": "Living Room Temperature",
        "platform": "esphome",
        "supported_features": 0,
        "translation_key": null,
        "unique_id": "esp01sensorliving_room_temperature",
        "unit_of_measurement": "?C"
EDIT: the issue occurs for all the instances of “°”, that is on every sensor that reports temperature.
Again, that is not a zwave sensor:
This is the same “sensor” as you showed above … If this has anything to do with your Daikin, then "remove/disable) this sensor , and try again and if it’s not to much hazzel, stop/prevent the Daikin-integration from load , to see whether that help … some time it better/easier to use the “exclude” approach to narrow down the culprit
btw are you sure you mean every “degree-sign sensors” ?, or could it be so that it actually just stops(and fails to start) on this occurrence ?
Quick update: for some reason the “°” symbol does not appear as a question mark in core.entity_registry anymore but appears properly as “°”. However, I still get the same error.
I have tried removing and adding back all the entities that contain temperature but the only success was what I mentioned in the first sentence of this post.
It really seems like a bug to me, do you guys have any other idea?
The problem is the encoding of the file, we have established that.
Next step i would have performed, is to “commend out” your automations( in conf.yaml), to see / verify that it’s not something in an self-made-automation that causes this
… but unfortunately, i simple " dot " in the wrong place in core.entity.registry is enough for ha to “prevent loading”
I have an update. Now for some reason core.entity_registry is empty and HA complains about it. I have to delete the empty file and restart HA to create a new one.
2023-01-18 12:17:04.808 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-18 12:17:07.435 ERROR (SyncWorker_2) [homeassistant.util.json] Could not parse JSON content: /home/homeassistant/.homeassistant/.storage/core.entity_registry
  File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/util/json.py", line 39, in load_json
    return orjson.loads(fdesc.read())  # type: ignore[no-any-return]
orjson.JSONDecodeError: input length is 0: line 1 column 1 (char 0)
EDIT: what is interesting is that my previous theory that all “°” are not readable by HA is wrong. I suppose that core.entity_registry is read from top to bottom and the character that breaks the file is not the first “°” that appears.
From which install-media/version to which version ? ,are you running Supervised on ubunty, or VMware homeassistant-os, on windows ?
I am running HA core 2023.1.4 on raspbian in venv. I upgraded from 2022.06.something
EDIT: I did not upgrade. I actually uninstalled and reinstalled HA as I was getting the error we are discussing about.
Good luck, im out
Problem solved!
I am a genius. I just had to reconfigure the locale of my system using dpkg-reconfigure locales and choose UTF8.
Thank you @Olivier1974 @boheme61 @tom_l for your support, it was highly appreciated and without your help I wouldn’t have been able to figure out the problem.
I had a similar issue with a migration to a new Raspberry pi 5. However, dpkg-reconfigure locales did not solve the issue. Here are the steps that were needed to solve the issue:
The file core.entity_registry was being saved as ISO-8859-1 and should be UTF-8. This can be checked with: file -i /home/homeassistant/.homeassistant/.storage/core.entity_registry
The file /etc/default/locale had not been updated completely. LANG was changed, but not LC_ALL After editing the file, it now works fine.
LANG=en_US.UTF-8
LANGUAGE=en_US.UTF-8
LC_ALL=en_US.UTF-8
If needed, the file can be converted to UTF-8 with: iconv -f ISO-8859-1 -t UTF-8//TRANSLIT core.entity_registry -o core.entity_registry
