Sorry to reply to my own comment, but it turns out I did not have a good connection when trying to bridge the cut tx trace. I ended up using a wire make the bridge. I was using an ohm meter to verify that I was getting continuity to the chip, but maybe I had shorted ground as well? So when I used the insulated wire and connected further back on the trace that might have prevented the short? Either way, it works now.
Sorry just getting back to you. Yeah your problem sounded exactly like one I addressed on the other discussion thread we have around here, which I was going to refer you to⦠but it seems you figured it out on your own!
