Count Green Pixels - Getting Sensor Values from Python code - need help
I created this python code with the help of ChatGPT and some personal adjustments. It counts the green pixels in 10 different tones from a rtsp-stream screenshot.
Can someone help me integrate this code to HA?
Maybe it can be executed every hour and return the numbers of pixels to HA, so we can keep a history and make a graph. Can you help me, please?
import cv2
import numpy as np
# Set up RTSP stream URL and credentials
# /stream1 is for a tapo camera
rtsp_url = "rtsp://USER:PASSWORD@IP:PORT/stream1"
# Open the RTSP stream
cap = cv2.VideoCapture(rtsp_url)
# Check if the stream is opened successfully
if not cap.isOpened():
    print("Error: Cannot open the RTSP stream.")
    exit()
# Full screen mode for OpenCV
cv2.namedWindow('RTSP Stream', cv2.WND_PROP_FULLSCREEN)
cv2.setWindowProperty('RTSP Stream', cv2.WND_PROP_FULLSCREEN, cv2.WINDOW_FULLSCREEN)
# Initialize the toggle list for 10 tones (all start as False/off)
replace_green_with_black = [False] * 10
text_color_black = [False] * 10  # To toggle text color for each tone
# Function to count and optionally replace different green tones with black
def process_frame(frame, replace_green_with_black):
    # Convert the frame to 8-bit
    frame_8bit = cv2.convertScaleAbs(frame)
    # Convert BGR to HSV for better color range detection
    hsv = cv2.cvtColor(frame_8bit, cv2.COLOR_BGR2HSV)
    # Define the renamed tones
    green_yellow_ranges = [
        ("rot braun  A-C", np.array([0, 20, 160]), np.array([15, 255, 255])),
        ("braun ", np.array([15, 50, 120]), np.array([20, 255, 255])),
        ("gelb braun ", np.array([20, 65, 120]), np.array([25, 255, 255])),
        ("gelb ", np.array([25, 65, 180]), np.array([30, 255, 255])),
        ("gelb gruen ", np.array([30, 65, 190]), np.array([35, 255, 255])),
        ("hell gruen ", np.array([35, 90, 180]), np.array([40, 255, 255])),
        ("helleres gruen", np.array([40, 90, 190]), np.array([45, 255, 255])),
        ("dunkleres gruen", np.array([45, 95, 120]), np.array([50, 255, 255])),
        ("dunkel gruen", np.array([50, 60, 170]), np.array([55, 255, 255])),
        ("nach gruen D-F", np.array([55, 60, 100]), np.array([70, 255, 255]))
    green_counts = {}
    mask_total = np.zeros(frame.shape[:2], dtype="uint8")  # Combined mask for selected tones
    for i, (tone_name, lower_bound, upper_bound) in enumerate(green_yellow_ranges):
        # Create a mask for this tone
        mask = cv2.inRange(hsv, lower_bound, upper_bound)
        # Count non-zero (green) pixels for this tone
        count = cv2.countNonZero(mask)
        # Store the count with the tone name
        green_counts[tone_name] = count
        if replace_green_with_black[i]:  # Check if replacement is toggled on for this tone
            mask_total = cv2.bitwise_or(mask_total, mask)  # Add this mask to the total mask
    # Replace the detected green pixels with black in the original frame
    frame[mask_total > 0] = [0, 0, 0]  # Set all green pixels to black where masks are active
    return frame, green_counts
while True:
    # Read frame from the RTSP stream
    ret, frame = cap.read()
    if not ret:
        print("Failed to grab frame.")
        break
    # Process the frame and count green pixels
    frame, green_counts = process_frame(frame, replace_green_with_black)
    # Overlay the green pixel counts on the frame in the bottom right corner
    text_x = frame.shape[1] - 500        # X coordinate for the text
    text_y = 50                          # Starting Y coordinate
    #text_y = frame.shape[0] - 300       # Starting Y coordinate
    # Loop through the green counts and display them
    for i, (tone_name, count) in enumerate(green_counts.items()):
        text = f"{i} - {tone_name}: {count}"
        # Toggle text color based on user input (black or green)
        color = (0, 0, 0) if text_color_black[i] else (0, 255, 0)  # Black or green text color
        cv2.putText(frame, text, (text_x, text_y + i * 30), cv2.FONT_HERSHEY_SIMPLEX, 0.8, color, 2, cv2.LINE_AA)
    # Display the frame
    cv2.imshow('RTSP Stream', frame)
    # Handle keyboard input
    key = cv2.waitKey(1) & 0xFF
    if key == ord('q'):  # Press 'q' to quit
        break
    elif ord('0') <= key <= ord('9'):  # Toggle replacement of each tone (keys 0-9)
        index = key - ord('0')
        replace_green_with_black[index] = not replace_green_with_black[index]
        text_color_black[index] = not text_color_black[index]  # Toggle text color for each tone
# Release the video capture object and close the window
cap.release()
cv2.destroyAllWindows()
