Count people that are home
What this error means:
expected an indented block in on statement: state = hass.states.get(entity_id)
Hi, very good python script.
Is it possible to filter some people by the friendly_name ?
Found it by myself
for entity_id in hass.states.entity_ids('device_tracker'):
  if state.name == 'XXXXX':
   continue
  if state.state == 'home':
			home = home + 1
You can also use the persons:
home_count = 0
home_desc = ""
inuse_count = 0
inuse_desc = ""
summary = ""
for entity_id in hass.states.entity_ids('person'):
        home_count = home_count + 1
        home_desc = home_desc + state.name + ', '
if home_count > 0:
    home_desc = str(home_count) + ' Personen: ' + home_desc[:-2]
else:
    home_desc = 'Niemand zu Hause'
summary = home_desc
hass.states.set('sensor.people_home', home_desc, {
    'friendly_name': 'Personen zu Hause'
o dear this has been a long time…
evolved from the summary script quite extensively, and, using the people counter has become this in my setup:
familyEntities = 'group.family_home'
daughterEntities = 'group.daughters_home'
familyColor = ['grey',  # count_home = 0 #808080
               'steelblue',  # = 1
               'saddlebrown',      # = 2 #00f
               'gold',   # = 3 #fbd229
               'darkorange',    # = 4 #ff8700
               'maroon',     # = 5 #ff0f00
               'green']      # = 6
familyIcon = ['mdi:account-off',      # count_home = 0
              'mdi:account',          # = 1
              'mdi:account-multiple', # = 2
              'mdi:account-multiple-check', # = 3
              'mdi:account-group']    # > 3
utc_offset = hass.states.get('sensor.utc_offset').state
timeDifference = float(utc_offset)
def CountMyEntities(hass, entity_list, entity_state=None, not_state=None):
    cnt = 0
    for entity_id in hass.states.get(entity_list).attributes['entity_id']:
        if entity_state is not None and state.state == entity_state:
            cnt = cnt + 1
        if not_state is not None and state.state != not_state:
            cnt = cnt + 1
    return cnt
count_home = CountMyEntities(hass, familyEntities, 'home')
count_away = CountMyEntities(hass, familyEntities, not_state='home')
daughter_count_home =  CountMyEntities(hass, daughterEntities, 'home')
daughter_count_away =  CountMyEntities(hass, daughterEntities, not_state='home')
def NameMyEntities(hass, entity_list, entity_state=None, not_state=None):
    global timeDifference
    names = []
        dt = state.last_changed + datetime.timedelta(hours= timeDifference)
        time = '%02d:%02d' % (dt.hour, dt.minute)
            name = '{} ({})'.format(state.attributes['friendly_name'], time)
            names.append(name)
            names.append(name)
    return names
home = NameMyEntities(hass,familyEntities,'home')
away = NameMyEntities(hass,familyEntities,not_state='home')
daughter_home = NameMyEntities(hass,daughterEntities,'home')
daughter_away = NameMyEntities(hass,daughterEntities,not_state='home')
familyCount = count_home + count_away
daughterCount= daughter_count_home + daughter_count_away
daughterIcon = familyIcon[daughter_count_home] if daughter_count_home <= 3 else familyIcon[-1]
whichIcon = familyIcon[count_home] if count_home <= 3 else familyIcon[-1]
# the % symbol is mod, that means it will cycle through the list and never get 'Index out of range'
icon_color = familyColor[count_home%len(familyColor)]
daughter_icon_color = familyColor[daughter_count_home%len(familyColor)]
hass.states.set('sensor.family_home',count_home,{
    'friendly_name':'Family Home?',
    'home':', '.join(home),
    'away':', '.join(away),
    'icon':whichIcon,
    'count_home':count_home,
    'count_away':count_away,
    'family_count':familyCount,
    'icon_color':icon_color
hass.states.set('sensor.daughters_home',daughter_count_home,{
    'friendly_name':'Daughters Home?',
    'home':', '.join(daughter_home),
    'away':', '.join(daughter_away),
    'icon':daughterIcon,
    'count_home':daughter_count_home,
    'count_away':daughter_count_away,
    'daughter_count':daughterCount,
    'icon_color':daughter_icon_color
does a few more things, guards for None entities, checks the correct time using sensor.utc_offset and customizes (because python created entities cant be customized using regular ha customize: )
Isn’t this easier to just use?
{{states.person|selectattr('state', '==', 'home')|list|count}}
I did the same and actually it works quite fine for me… just counting the persons at home of course… YAMIL script works as sensor in my case, actually I would test a group with the ā€œexpandā€ function so that it would be easy to enlarge or reduce the group when necessary instead of listing person.person1…X in the sensor code.
I’d suggest, yes :slight_smile:
Thanks, saved me the effort of working this out :grinning_face_with_smiling_eyes:
Using a recent version of Home Assistant it is even easier, as zones now have a state representing the number of persons in it:
{{ states('zone.home') | int }}
Thanks. That is great, but not intuitive as to what is being counted. It could just as easily be counting areas. If I came back to it I’d be wondering what that was :laughing:
But it is more efficient, especially when defining triggers on it. As the alternative template is iterating over states, I guess it reverts to polling to check for changes, whereas a single entitiy state is a simple event. And in the gui, it can be used without reverting to yaml / jinja.
As to intuitiveness, there’s not that much zones do, other then checking if persons enter it. So what else could it truely be? Area’s have no relation to zones.
Well, it is in the document:
Zone - Home Assistant (home-assistant.io)
… also mentioned in the release notes, with screenshots and examples:
2022.4 - Zones now have a state!
It counts people, even when you have multiple device trackers tying to different persons.
Obviously one could still do complex templating and scripting to fit whatever specific needs - there are many ways to skin a cat.
I’m old fashioned - I was taught that variables/states should have meaningful names like zone.person_home_count. But hey ho - the ā€˜modern’ way :frowning:
They briefly considered renaming ā€œstateā€ to ā€œnumber_of_persons_in_itā€ but that resulted on people staring at their lightbulbs to check there was no one there :crazy_face:
But you can name your zone entities anything you like, so that is not a problem. Only not home, but you could create an extra zone in the same place too. Although, that might lead to other trouble.
