I can understand you completely - no bad feelings.
I will try to get this fixed in github.
Hey did you fix everything in your setup?
I just saw this integration and don’t know how to set it up. How to listen to the events sended through webhook? Maybe you can help me in German. I want to flash lights with WLED Integration.
I am not sure if it is allowed to anser in german so I will do it both.
Yes - I was able to integrate it (not yet completely perfect). I had to fiddle around with the timeouts a little bit and now from the second round on it works (nealy 100%) as intended.
I wasn’t able to finalize the configuration but thats the problem when stuff works sufficient and the user is lazy f*ck
I am going to copy and paste my config sections later on when I am home.
German:
Ja - die Integration läuft fast perfect. Ich musste ein paar timeouts anpassen damit die Lichter richtig reagieren und ab der zweiten Runde läufts nun fast so wie es soll.
Leider hab ich noch nicht die Zeit gefunden das zu finalisieren - so ist das halt wenn es zufriedenstellend läuft und man keine Zeit oder Lust derzeit hat das zu reparieren.
Ich poste nachher mal meine Konfiguration wenn ich zu Hause bin.
##this i got in the scripts.yaml
csgo_freezetime:
alias: CSGO - Freezetime
sequence:
- data:
entity_id:
- script.csgo_flashloop1
- script.csgo_flashloop2
service: script.turn_off
- data:
rgb_color:
- 61
- 119
- 255
transition: 0.5
service: light.turn_on
device_id:
- c5bbc1d5c881f36f604eb5559aacb2cc
mode: single
csgo_begin_end:
alias: CSGO - Round start/end
sequence:
- data:
entity_id:
- service: light.turn_on
rgb_color:
- 255
- 217
- 128
device_id:
mode: single
csgo_bomb_planted:
alias: CSGO - Bomb planted
sequence:
- data:
rgb_color:
- 255
- 190
- 0
transition: 0.5
device_id:
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
enabled: true
- service: script.csgo_flashloop1
data: {}
mode: single
csgo_bomb_defused:
alias: CSGO - Bomb defused
sequence:
- data:
entity_id:
- data:
rgb_color:
- 0
- 255
- 0
transition: 0.5
device_id:
mode: single
csgo_bomb_exploded:
alias: CSGO - Bomb exploded
sequence:
- data:
entity_id:
- data:
rgb_color:
- 255
- 0
- 0
transition: 0.5
device_id:
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
mode: single
csgo_flashloop1:
alias: CSGO - Flashloop 1
sequence:
- data: {}
entity_id: script.csgo_flashloop2
- service: script.csgo_flashloop2
data: {}
- data:
flash: long
device_id:
- delay:
hours: 0
minutes: 0
seconds: 15
milliseconds: 0
mode: single
csgo_flashloop2:
alias: CSGO - Flashloop 2
sequence:
- delay: '1'
enabled: true
- timeout: 00:00:15
wait_template: '{{ states.script.csgo_flashloop1.state == "off" }}'
data: {}
mode: single
licht_flash_buro:
alias: Licht flash büro
sequence:
flash: short
device_id:
- 501694fdfbf962586a75f59fd809fd55
mode: single
You have to amend the script afterwards to which light you want to react to the commands - you can do this in the UI.
## this sections you have to add to the automations.yaml
- id: '00000002'
alias: CSGO - Round starts or game ends
description: Start-Ende
- event_data: {}
event_type: csgo_round_started
platform: event
- event_data: {}
event_type: csgo_game_stopped
platform: event
enabled: false
condition:
- condition: device
device_id: ba5595f32384b556babca3fcaa3c4b36
domain: light
entity_id: light.tischbeleuchtung_buro
type: is_on
- data: {}
entity_id: script.csgo_begin_end
service: script.turn_on
- id: '00000003'
description: ''
- event_data: {}
event_type: csgo_bomb_planted
platform: event
condition:
- condition: device
domain: light
type: is_on
- data: {}
entity_id: script.csgo_bomb_planted
- id: '00000004'
description: ''
- event_data: {}
event_type: csgo_bomb_exploded
platform: event
condition:
- condition: device
domain: light
type: is_on
- data: {}
entity_id: script.csgo_bomb_exploded
- id: '00000005'
description: ''
- event_data: {}
event_type: csgo_bomb_defused
platform: event
condition:
- condition: device
domain: light
type: is_on
- data: {}
entity_id: script.csgo_bomb_defused
And after you added this you also have to amend the automation in the UI to your lights that you want to change
my gamestate_integration_homeassistant.cfg looks like this
"HomeAssistant Integration v1.2.0"
"uri" "http://192.168.178.66:8123/api/webhook/c397a20f48d859bda68746426a46b58c7c7ce2c126a187e58f7fb3d0cd4c347a"
"timeout" "5.0"
"buffer" "0.1"
"throttle" "0.1"
"heartbeat" "60.0"
"data"
"round" "1" // round phase, bomb state and round winner
I sincerely hope this helps you
