Simply group the entities of the sensors
Sorry, but could you explain further what you mean? A code snipit would definitely help
Have a read through here: https://www.home-assistant.io/components/group/
Necro-post for anyone else looking for this information.
Naming for eth0 on NUCs has changed. On my system it is now:
- platform: systemmonitor
resources:
- type: throughput_network_in
arg: enp2s0
- type: throughput_network_out
arg: enp2s0
More info here:
Buster right?
Not sure. Hassio NUC image.
I am on a NUC / hassio / ubuntu installation.
For me the ff. config worked for the network part:
resources:
- type: network_in
arg: hassio
- type: network_out
arg: eno1
so eno1 or hassio is working either
you can check the ethernet adapters on a console of the host
ip a
or
ipconfig -a
the result looks like:
fregatte
I have only eth0 but don’t work the sensor network_in and out.
Any idea ??
Hey! I have the same problem, did you manage to sort it out?
Got some values with this
arg: hassio
arg: hassio
That did the trick for me aswell
