Create automation for randomize switch output
Hi all,
i bought a HLK-SW16 relay module and i configured it into HA.
I want to create two automation/script to start a loop where
an automation turn on one of 8 relay for 5 seconds in a random selection.
an automation that rotate between 64 combination of on/off state (2^8 possibilities) for 5 seconds
From HA i will decide manually with a switch when start the automation
Someone have done something of similar or give me an hints to start?
There’s some information on using the random method here that might help you:
How’s the relay represented in HA? To turn on one of the 64 combinations, what do you have to pass to the relay?
The entity is entity_id: switch.relay1_0
For every combination I need to power on or off every relay
try this
    platform: time_pattern
    # You can also match on interval. This will match every 5 minutes
    minutes: '/5'
    - service: switch.turn_on
      data_template:
        entity_id: >
          {%- macro getrelays() %}
          {%- set relay = 'switch.relay1_' %}
          {%- set flags = '{:08b}'.format(range(256) | random) | list %}
          {%- for i in range(flags | length) %}
          {{- relay+'{} '.format(i) if flags[i] == '1' else '' }}
          {%- endfor %}
          {%- endmacro %}
          {{ getrelays().strip().split(' ') | join(', ') }}
Then just turn on and off this automation.
EDIT: I Just realized yours goes all the way to 8 from 0… that would be more than 64 combos. That’s 511 combinations… so you’d want to change this line to account for that.
          {%- set flags = '{:09b}'.format(range(511) | random) | list %}
EDIT2: I made a simple one where you just change the inputs
    minutes: '/5'
      data_template:
        entity_id: >
          {%- set relay_count = 9 %}
          {%- set bin = '1' * relay_count %}
          {%- set rng = bin | int(bin, 2) %}
          {%- set fmat = '{'+':0{}b'.format(relay_count)+'}' %}
          {%- set flags = fmat.format(range(rng) | random) | list %}
          {%- endfor %}
          {%- endmacro %}
