Can you set up another basic timer, using the timer component and see if that works. That will tell you if you have enabled all you need in your front end.
How can I do that?
Hey,
First of all thanks for sharing the code!
I have a problem setting the automation, probably with the syntax
(when I trigger the automation manually it works)
I use the automation editor
Can you help me with it?
The automation editor does have it’s limitations, IMHO.
You’ll be better off using an editor like X Code.
All automations, when triggered will action the output. It doesn’t really tell you much in this case.
Can you post your actual code?
thanks for your reply.
I manage to fix it.
