For each of these I need to manually add and configure the integration one by one for each of the sensors. Is it possible to automate this?
I am envisioning either a template loop in a configuration to add all the desired entities, or a match rule against which the integration creates entities.
Thanks for the pointer to using a temporary template to generate a yaml snippet. I can use that for thermal_comfort, but unfortunately mold_risk_index gives me an error: "The mold_risk_index integration does not support YAML setup, please remove it from your configuration"
I will look into using the API to create missing entities (but it looks like this is not perfect:
