Yes here are some of the sensors YR creates.
And as mentioned earlier sensor.weather_temperature
and sensor.weather_wind_speed
is the ones @rkarlsba is looking for
Well, what’s wrong with this?
Every sensor you use must be “states.(entit_id).state | float”, e.g. “states.sensor.weather.temperature.state | float”
Doing so however returns a result below zero, so I guess there’s an error in the formula as well.
{{ states.yr.weather_temperature.state | float }}
{{ states.sensor.weather_temperature.state | float }}
Both give me ‘Error rendering template: UndefinedError: ‘None’ has no attribute ‘state’’
…and
For loop example:
{% for state in states.sensor -%}
{%- if loop.first %}The {% elif loop.last %} and the {% else %}, the {% endif -%}
{{ state.name | lower }} is {{state.state_with_unit}}
{%- endfor %}.
Says
For loop example:
The cpu temperature is 44.39 °C, the hygrometer på pi is 21.1 %, the termometer på pi is 27.0 °C, the windchill is unknown, the yr humidity is 84.5 %, the yr precipitation is 0.3 mm, the yr pressure is 1007.2 hPa, the yr symbol is 13, the yr temperature is -2.1 °C and the yr wind speed is 3.7 m/s.
And then
{{ states.sensor.weather_temperature | float }}
Tells me 0.0
Here is a thread about humidity and temp to calculate chill effect Heat Index / Apparent Temperature / Feels Like Temperature
Here is a link that describes both humid chill index and wind chill index http://www.physlink.com/Reference/Weather.cfm
Here is another one with only wind chill index where you can specify units depending on what sensor you are using http://www.calculator.net/wind-chill-calculator.html
Please follow the examples closely before posting.
It looks like you’re just trying stuff you don’t fully understand. It might be wise to read some of the documentation first.
This is based on humidity and temperature from YR
sensors:
chill_index:
value_template: '{{ (((((((states.sensor.weather_temperature.state|float)*1.8)+32) + 61.0 + (((((states.sensor.weather_temperature.state|float)*1.8)+32)-68.0)*1.2) + ((states.sensor.weather_humidity.state|float)*0.094))*0.5)-32)/1.8)|round(1) }}'
Thanks, but… Technically, it works, but AFAICS the formula is wrong. Compared it with yr, and what’s on their website shows a far lower windchill than this, that is, measured in celsius
Edit: That is, it’s said to be an index - does that mean it should be added to the temperature?
check this:
@Mariusthvdb when i tried your sensors i get error:
“Could not render template Jag/Ti Wchill, the state is unknown.”
doing their job here:
maybe you didnt define the sensors this template sensor uses? I use platform Buienradar Buienradar - Home Assistant
I had missed one character
Now i have both on humidity and wind based on different formulas and a average based on them.
Looking good!
Could you please share your code?
Here it is. Using both sensors from YR.no, other sensors and code from @Mariusthvdb Mariusthvdb
sensors:
heat_index_1:
unit_of_measurement: '°C'
jagti_windchill:
value_template: '{{ (13.12 + 0.6215*float(states.sensor.weather_temperature.state) + 0.3965*(float(states.sensor.weather_temperature.state) - 28.676) *(float(states.sensor.weather_wind_speed .state)*3.6)**0.16) | round(2) }}'
friendly_name: Jag/Ti Wchill
# Tchill(°C) = 13,12 + 0,6215*Tair + 0.3965*(Tair - 28,676)*S10m0,16
# S10m = windspeed (km/h) at anemometer_height = 10 m, Tair in °C
jagti_windchill_2:
value_template: '{{(13.12 +0.6215*float(states.sensor.weather_temperature.state) -11.37*(float(states.sensor.weather_wind_speed.state)*3.6)**0.16 +0.3965*float(states.sensor.weather_temperature.state)*(float(states.sensor.weather_wind_speed.state)*3.6)**0.16) | round(2) }}'
friendly_name: Jag/Ti Wchill v2
#G =13,12+0,6215*T-11,37*(W*3,6)^0,16+0,3965*T*(W*3,6)^0,16
#Invoerveld T = Temperatuur in Graden Celsius
#Invoerveld W = Wind in meter / seconde
steadman_windchill:
value_template: '{{ (1.41 - 1.162*float(states.sensor.weather_wind_speed.state) + 0.98*float(states.sensor.weather_temperature.state) + 0.124*float(states.sensor.weather_wind_speed.state)**2 +0.0185*float(states.sensor.weather_wind_speed.state)*float(states.sensor.weather_temperature.state)) | round(2) }}'
friendly_name: Steadman Wchill
# Tchill(°C) = 1.41 - 1.162*S + 0.98*Tair+0.0124*S2 + 0.0185*S*Tair
# Tair in °C en S= in m/s.
- platform: min_max
type: mean
entity_ids:
- sensor.heat_index_1
- sensor.jagti_windchill
- sensor.jagti_windchill_2
- sensor.steadman_windchill
- sensor.pws_feelslike_c
- platform: min_max
type: mean
entity_ids:
- sensor.weather_temperature
- sensor.pws_temp_c
- sensor.net_utomhus_temperature
