Seems something strange on your tasker…
From what I’m seeing, all your tasks are correct… Hmmm…
Try to use a global variable instead of a local variable?
If that doesnt work, try to put the switch/turn_on in your %HASS_SERVICE (adding at the end), and try to execute without %service, so you would have %HASS_SERVICE%HASS_PSW
Have you tried to use just http post, without variables? will that execute?
Either way, I think there is something wrong with your tasker… On my (nexus) devices, it has been working always flawlessly. I never had any issues…
Yes, no problem… Match regex, means if Tasker recognize anything what you say, it will execute that…
Eg: it should even work if you say: blablabla, put on blababla living room lights… So it recognize the word ON and LIVING ROOM LIGHTS…
So that way, you have a lot of freedom, what you say to your phone
I have a different problem now. Tasker and AutoVoice are working as expected, but my normal Google search no longer works, because whatever I say, I get a toast notification “Received possible command: …” and my Google search closes - seems that AutoVoice is interferring.
If I say: “What’s the time?” it gets recognized perfectly, and phone start to speak out aloud the time, I even see the search result but it gets interrupted between and closes.
Trying to set up. Having a problem with profile.
When i go to profile
Event->Plugin->Autovoice->Recognized
Than press the pen button on the upper right.
Than have to select “The Hard Way”
Than go to command filter and enter
(?.+) (?.+) and than go back it show up as
Command: Not “(?< task >.+) my (?< device >.+) (regex) (exact)”
After i go to the edit mode i see that there is a check mark on Command filter invert. I uncheck it go back. But it just stays as Not…
Maybe I am making a noob question but isn’t it possible to give to the community the Tasker xml so that everyone could use the same? Or some sort of file that we could import?
Thanks for this awesome tutorial. However, my setup is not really reliable.
The problem is that Autovoice does not always works. I have tested it on 2 different devices, but Autovoice only fires the commands 1 out 4 times. Google Now opens up, the voice command is properly recognized by GN, but Autovoice just won’t do a thing
Any ideas?
It used to work great for me too. Let me get a deeper look at all the logs… But still, it’s really strange that I get this behaviour on both my mobile phone and the Android box :-/
