This is how I got it working. I might tidy up code further but do not have the time…
- unzip into custom_components it should be a climote folder with all the files in it - maybe here you got the structure wrong
- restart HA
- add in configuration.yaml (of course update your secrets.yaml file with your credentials
climate:
- platform: climote
username: !secret climote_user
password: !secret climote_pass
id: !secret climote_id
refresh_interval: 4
- restart HA
I have used a series of buttons and timers helpers and rules to turn the heating on and off for 30 min
dashboard code
cards:
- type: entities
entities:
- entity: input_boolean.boost_living
- entity: timer.heating_living
- entity: input_boolean.boost_bedrooms
- entity: timer.heating_bedrooms
- entity: input_boolean.boost_water
- entity: timer.heating_water
title: Climote controls
state_color: true
show_header_toggle: false
rules - sample for water, duplicate and change for bedrooms and living
alias: Boost_water_on
description: ''
- platform: state
entity_id: input_boolean.boost_water
to: 'on'
condition: []
- service: climate.set_hvac_mode
hvac_mode: heat
entity_id: climate.water
- delay:
hours: 0
minutes: 0
seconds: 4
milliseconds: 0
- service: timer.start
duration: '0'
entity_id: timer.heating_water
mode: single
alias: Boost_water_off
description: ''
- platform: state
to: 'off'
condition: []
hvac_mode: 'off'
- delay:
hours: 0
minutes: 0
seconds: 4
milliseconds: 0
- service: timer.finish
data: {}
mode: single
alias: Boost_water_done
description: ''
- platform: state
to: idle
for: '00:00:02'
condition: []
- service: automation.turn_off
data: {}
entity_id: automation.boost_water_on
data: {}
entity_id: automation.boost_water_off
- service: input_boolean.turn_off
data: {}
- service: automation.turn_on
data: {}
data: {}
mode: single
here is my version of climate.py
import logging
import polling
import json
import xmljson
import lxml
from lxml import etree as ET
import voluptuous as vol
from datetime import timedelta
from bs4 import BeautifulSoup
import requests
from homeassistant.util import Throttle
import homeassistant.helpers.config_validation as cv
from homeassistant.components.climate import (
ClimateEntity, PLATFORM_SCHEMA)
from homeassistant.components.climate.const import (SUPPORT_TARGET_TEMPERATURE, HVAC_MODE_OFF, HVAC_MODE_HEAT,CURRENT_HVAC_HEAT,CURRENT_HVAC_IDLE)
from homeassistant.const import (
CONF_ID, CONF_NAME, ATTR_TEMPERATURE, CONF_PASSWORD,
CONF_USERNAME, TEMP_CELSIUS, CONF_DEVICES)
_LOGGER = logging.getLogger(__name__)
MIN_TIME_BETWEEN_UPDATES = timedelta(minutes=60)
#: Interval in hours that module will try to refresh data from the climote.
CONF_REFRESH_INTERVAL = 'refresh_interval'
NOCHANGE = 'nochange'
DOMAIN = 'climote'
ICON = "mdi:thermometer"
MAX_TEMP = 35
MIN_TEMP = 5
#SUPPORT_FLAGS = (SUPPORT_ON_OFF | SUPPORT_TARGET_TEMPERATURE)
SUPPORT_FLAGS = SUPPORT_TARGET_TEMPERATURE
SUPPORT_MODES = [HVAC_MODE_HEAT, HVAC_MODE_OFF]
#DEVICE_SCHEMA = vol.Schema({
# vol.Required(CONF_ID): cv.positive_int,
# vol.Optional(CONF_NAME): cv.string,
#}, extra=vol.ALLOW_EXTRA)
def validate_name(config):
"""Validate device name."""
if CONF_NAME in config:
return config
climoteid = config[CONF_ID]
name = 'climote_{}'.format(climoteid)
config[CONF_NAME] = name
return config
# CONFIG_SCHEMA = vol.Schema(
# DOMAIN: vol.Schema(
# vol.Required(CONF_USERNAME): cv.string,
# vol.Required(CONF_PASSWORD): cv.string,
# vol.Required(CONF_ID): cv.string,
# vol.Optional(CONF_REFRESH_INTERVAL, default=24): cv.string,
# extra=vol.ALLOW_EXTRA,
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
# vol.Required(CONF_DEVICES):
# vol.Schema({cv.string: DEVICE_SCHEMA})
def setup_platform(hass, config, add_entities, discovery_info=None):
"""Set up the ephember thermostat."""
_LOGGER.info('Setting up climote platform')
username = config.get(CONF_USERNAME)
password = config.get(CONF_PASSWORD)
climoteid = config.get(CONF_ID)
interval = int(config.get(CONF_REFRESH_INTERVAL))
# Add devices
climote = ClimoteService(username, password, climoteid)
if not (climote.initialize()):
return False
entities = []
for id, name in climote.zones.items():
entities.append(Climote(climote, id, name, interval))
add_entities(entities)
return
#new function added
# async def async_setup(hass, config):
# """Set up Climote components."""
# if DOMAIN not in config:
# return True
# conf = config[DOMAIN]
# config_flow.register_flow_implementation(
# hass, conf[CONF_CLIENT_ID], conf[CONF_CLIENT_SECRET]
# return True
# async def async_setup_entry(hass, config, async_add_entities,
# discovery_info=None):
# """Set up the climote platform."""
# _LOGGER.info('Setting up climote platform')
# _LOGGER.info('usernamekey:%s', CONF_USERNAME)
# username = config.get(CONF_USERNAME)
# password = config.get(CONF_PASSWORD)
# interval = int(config.get(CONF_REFRESH_INTERVAL))
# # Add devices
# climote = ClimoteService(username, password, climoteid)
# if not (climote.initialize()):
# return False
# entities = []
# for id, name in climote.zones.items():
# entities.append(Climote(climote, id, name, interval))
# add_entities(entities)
class Climote(ClimateEntity):
"""Representation of a Climote device."""
def __init__(self, climoteService, zoneid, name, interval):
"""Initialize the thermostat."""
_LOGGER.info('Initialize Climote Entity')
self._climote = climoteService
self._zoneid = zoneid
self._name = name
self._force_update = False
self.throttled_update = Throttle(timedelta(hours=interval))(self._throttled_update)
@property
def supported_features(self):
"""Return the list of supported features."""
return SUPPORT_FLAGS
@property
def hvac_mode(self):
# """Return current operation ie. heat, cool, idle."""
# return 'idle'
"""Return current operation. ie. heat, idle."""
zone = "zone" + str(self._zoneid)
return 'heat' if self._climote.data[zone]["status"] == '5' else 'idle'
@property
def hvac_modes(self):
"""Return the list of available hvac operation modes.
Need to be a subset of HVAC_MODES.
return SUPPORT_MODES
@property
def name(self):
"""Return the name of the thermostat."""
return self._name
@property
def icon(self):
"""Return the icon to use in the frontend."""
return ICON
@property
def temperature_unit(self):
"""Return the unit of measurement."""
return TEMP_CELSIUS
@property
def target_temperature_step(self):
"""Return the supported step of target temperature."""
return 1
@property
def current_temperature(self):
_LOGGER.info("current_temperature: Zone: %s, Temp %s C",
zone, self._climote.data[zone]["temperature"])
return int(self._climote.data[zone]["temperature"]) \
if self._climote.data[zone]["temperature"] != '--' else 0
# @property
# def is_on(self):
# """Return current operation. ie. heat, idle."""
# zone = "zone" + str(self._zoneid)
# return True if self._climote.data[zone]["status"] == '5' else False
@property
def min_temp(self):
"""Return the minimum temperature."""
return MIN_TEMP
@property
def max_temp(self):
"""Return the maximum temperature."""
return MAX_TEMP
@property
def target_temperature(self):
"""Return the temperature we try to reach."""
_LOGGER.info("target_temperature: %s",
self._climote.data[zone]["thermostat"])
return int(self._climote.data[zone]["thermostat"])
@property
def hvac_action(self):
"""Return current operation."""
return CURRENT_HVAC_HEAT if self._climote.data[zone]["status"] == '5' \
else CURRENT_HVAC_IDLE
def set_hvac_mode(self,hvac_mode):
if(hvac_mode==HVAC_MODE_HEAT):
"""Turn Heating Boost On."""
res = self._climote.boost(self._zoneid, 0.5)
self._force_update = True
return res
if(hvac_mode==HVAC_MODE_OFF):
# def turn_off(self):
"""Turn Heating Boost Off."""
res = self._climote.boost(self._zoneid, 0)
if(res):
return res
def set_temperature(self, **kwargs):
"""Set new target temperature."""
temperature = kwargs.get(ATTR_TEMPERATURE)
if temperature is None:
return
res = self._climote.set_target_temperature(1, temperature)
if(res):
return res
async def async_update(self):
"""Get the latest state from the thermostat."""
#if self._force_update:
# asyncio.run_coroutine_threadsafe(throttled_update(hass,self,no_throttle=True) , hass.loop)
# self._force_update = False
#else:
# asyncio.run_coroutine_threadsafe(throttled_update(hass,target,no_throttle=False) , hass.loop)
async def _throttled_update(self, **kwargs):
"""Get the latest state from the thermostat with a throttle."""
_LOGGER.info("_throttled_update Force: %s", self._force_update)
self._climote.updateStatus(self._force_update)
class IllegalStateException(RuntimeError):
def __init__(self, arg):
self.args = arg
_DEFAULT_JSON = (
'{ "holiday": "00", "hold": null, "updated_at": "00:00", '
'"unit_time": "00:00", "zone1": { "burner": 0, "status": null, '
'"temperature": "0", "thermostat": 0 }, "zone2": { "burner": 0, '
'"status": "0", "temperature": "0", "thermostat": 0 }, '
'"zone3": { "burner": 0, "status": null, "temperature": "0", '
'"thermostat": 0 } }')
_LOGIN_URL = 'https://climote.climote.ie/manager/login'
_LOGOUT_URL = 'https://climote.climote.ie/manager/logout'
_SCHEDULE_ELEMENT = '/manager/edit-heating-schedule?heatingScheduleId'
_STATUS_URL = 'https://climote.climote.ie/manager/get-status'
_STATUS_FORCE_URL = _STATUS_URL + '?force=1'
_STATUS_RESPONSE_URL = ('https://climote.climote.ie/manager/'
'waiting-get-status-response')
_BOOST_URL = 'https://climote.climote.ie/manager/boost'
_SET_TEMP_URL = 'https://climote.climote.ie/manager/temperature'
_GET_SCHEDULE_URL = ('https://climote.climote.ie/manager/'
'get-heating-schedule?heatingScheduleId=')
class ClimoteService:
def __init__(self, username, password, passcode):
self.s = requests.Session()
self.s.headers.update({'User-Agent':
'Mozilla/5.0 Home Assistant Climote Service'})
self.config_id = None
self.config = None
self.logged_in = False
self.creds = {'password': username, 'username': passcode, 'passcode':password}
self.data = json.loads(_DEFAULT_JSON)
self.zones = None
def initialize(self):
try:
self.__login()
self.__setConfig()
self.__setZones()
# if not self.__updateStatus(False):
# self.__updateStatus(True)
return True if(self.config is not None) else False
finally:
self.__logout()
def __login(self):
r = self.s.post(_LOGIN_URL, data=self.creds)
if(r.status_code == requests.codes.ok):
# Parse the content
soup = BeautifulSoup(r.content, "lxml")
input = soup.find("input") # First input has token "cs_token_rf"
if (len(input['value']) < 2):
return False
self.logged_in = True
self.token = input['value']
_LOGGER.info("Token: %s", self.token)
#anchors = soup.findAll("a", href=True)
#for a in anchors:
# href = a['href']
# str = href
# if (str.startswith(_SCHEDULE_ELEMENT)):
# cut = str.find('&startday')
# str2 = str[:-(len(str)-cut)]
# self.config_id = str2[49:]
# _LOGGER.debug('heatingScheduleId:%s', self.config_id)
#the link was commented in latest Climote page, doing simple read from page content
str = r.text
sched = str.find(_SCHEDULE_ELEMENT)
if (sched):
cut = str.find('&startday',sched)
str2 = str[sched:-(len(str)-cut)]
return self.logged_in
def __logout(self):
_LOGGER.info('Logging Out')
r = self.s.get(_LOGOUT_URL)
_LOGGER.debug('Logging Out Result: %s', r.status_code)
return r.status_code == requests.codes.ok
def boost(self, zoneid, time):
_LOGGER.info('Boosting Zone %s', zoneid)
return self.__boost(zoneid, time)
def updateStatus(self, force):
try:
self.__login()
self.__updateStatus(force)
finally:
self.__logout()
def __updateStatus(self, force):
def is_done(r):
return r.text != '0'
res = None
tmp = self.s.headers
try:
# Make the initial request (force the update)
if(force):
r = self.s.post(_STATUS_FORCE_URL, data=self.creds)
else:
r = self.s.post(_STATUS_URL, data=self.creds)
# Poll for the actual result. It happens over SMS so takes a while
self.s.headers.update({'X-Requested-With': 'XMLHttpRequest'})
r = polling.poll(
lambda: self.s.post(_STATUS_RESPONSE_URL,
data=self.creds),
step=10,
check_success=is_done,
poll_forever=False,
timeout=120
if(r.text == '0'):
res = False
else:
self.data = json.loads(r.text)
_LOGGER.info('Data Response %s', self.data)
res = True
except polling.TimeoutException:
res = False
finally:
self.s.headers = tmp
return res
def __setConfig(self):
if(self.logged_in is False):
raise IllegalStateException("Not logged in")
r = self.s.get(_GET_SCHEDULE_URL
+ self.config_id)
data = r.content
xml = ET.fromstring(data)
self.config = xmljson.parker.data(xml)
_LOGGER.debug('Config:%s', self.config)
def __setZones(self):
if(self.config is None):
return
zones = {}
i = 0
_LOGGER.debug('zoneInfo: %s', self.config["zoneInfo"]["zone"])
for zone in self.config["zoneInfo"]["zone"]:
i += 1
if(zone["active"] == 1):
zones[i] = zone["label"]
self.zones = zones
def set_target_temperature(self, zone, temp):
_LOGGER.debug('set_temperature zome:%s, temp:%s', zone, temp)
res = False
try:
self.__login()
data = {
'temp-set-input[' + str(zone) + ']': temp,
'do': 'Set',
'cs_token_rf': self.token
r = self.s.post(_SET_TEMP_URL, data=data)
_LOGGER.info('set_temperature: %d', r.status_code)
res = r.status_code == requests.codes.ok
finally:
self.__logout()
return res
def __boost(self, zoneid, time):
"""Turn on the heat for a given zone, for a given number of hours"""
res = False
try:
self.__login()
data = {
'zoneIds[' + str(zoneid) + ']': time,
r = self.s.post(_BOOST_URL, data=data)
_LOGGER.info('Boosting Result: %d', r.status_code)
finally:
self.__logout()
return res
