I would love to see that as a forum text.
Example:
So green for latest release, orange for previous and red for older.
That way it’s easier to find issues for people that answer.
Example:
This would be cool!
Maybe suggest it as a recommendation
If we just add our nabu casa account link in our profile then it could be fetched I guess.
Slightly back on topic, using the template in the Dev Tools, the below gives me just the numbers.
(bad code I know)
{{ states.sensor.utilita_test.state.split('£')[2]|replace("']", ' ')|trim }}
{{ states.sensor.utilita_test.state.split("£")[1]|replace("'", '')|replace(",", '')|trim }}
However, when I add them to a template, the following happens
sensor.utilita_test
entity ‘disables’ in Home Assistant- platform: template
sensors:
utilita_gas:
friendly_name: "Utilita Gas"
unit_of_measurement: '£'
value_template: >-
Did you remove it from config?
And use {{ states('sensor.utilita_test').split("£")[1]|replace("'", '')|replace(",", '')|trim }}
that way it won’t create errors when unavailable
Ha, no, you have a good point there!
I noticed when I was rebooting HA to enable the new templates, I also had to run the API call to “create” the sensor.utilita_test
entity
The below now works if I trigger the API call after I’ve rebooted HA.
sensors:
utilita_electric:
friendly_name: "Utilita Electric"
value_template: >-
sensors:
utilita_gas:
value_template: >-
{{ states('sensor.utilita_test').split("£")[2]|replace("'", '')|replace(",", '')|replace("]", '')|trim }}
I made a webpage that can give us a signature image with the version number we have installed.
If you can’t see the image then you need to enable the signatures in your profile.
You need three sensors:
Borrowing from tom_I, WTH don't I get notifications about available updates? - #3 by tom_l
- platform: version
image: intel-nuc # change for your system, see https://www.home-assistant.io/integrations/version/
source: local
- platform: version
image: raspberrypi4 # change for your system, see https://www.home-assistant.io/integrations/version/
source: hassio
- platform: rest
resource_template: >-
http://www.hoppvader.nu/hass/version.php?version={{states('sensor.installed_version') }}&latest={{states('sensor.latest_version') }}&user=Hellis81
value_template: '1' # dummy value
scan_interval: 86400
You need to change the username in the rest URL.
This will then result in a image being created on my webpage that you can link to as a signature using:
<img src="http://www.hoppvader.nu/hass/version.php?user=Hellis81">
And obviously changing the username.
Great idea, but would you mind sharing the php code?
I guess a lot of people (including me ) won’t feel at ease with injecting code from a unknown website
Sure…
But PHP has the advantage that it runs on the server thus the client is safe.
<?php
if($_GET["version"] !="" and $_GET["user"] !="" and $_GET["latest"] !=""){
header('Content-Type: image/png');
$img = imagecreatefrompng('HA.png');
$white = imagecolorallocate($img, 255, 255, 255);
$red = imagecolorallocate($img, 255, 0, 0);
$orange = imagecolorallocate($img, 255,165,0);
$green = imagecolorallocate($img, 255, 0, 0);
$age = explode(".", $_GET["latest"])[1] - explode(".", $_GET["version"])[1];
if($age == 0){
$color = $green;
}elseif($age == 1){
$color = $orange;
}else{
$color = $red;
$font = 'arial.ttf';
$x = 80;
$y = 50;
imagettftext($img, 18, 0, $x+1, $y+1, $white, $font, $_GET["version"]);
imagettftext($img, 18, 0, $x, $y, $color, $font, $_GET["version"]);
imagepng($img, $_GET["user"] . ".png");
imagedestroy($img);
}elseif($_GET["version"] == "" and $_GET["user"] !="" ){
header("Cache-Control: no-store, no-cache, must-revalidate, max-age=0");
$img = imagecreatefrompng($_GET["user"] . ".png");
imagepng($img);
So the if() is if you have all variables set, then it creates a png with the version number you have and with the filename [username].png.
else, it returns the image [username].png, meaning when the forum wants the image.
I just noticed the code to the signature had been replaced with an image in a code block.
edited-
