just a cutout and some command velco strips. You can probably make a DIY mount out of steel or something, the official one ‘holds on’ with magnets in the back of the panel.
I can see if I can save them if I see them going to trash…
There is a table mount too but its not pretty in my opinion. the 1070 table version is prettier.
Does the app reload when coming out of standby for everyone else? These work pretty great so far in my testing except for 2 issues:
The brightness control is only high or low, rather than variable. This is a very minor issue, but would be nice to have a more refined experience.
If I enable standby (so the screen is off when not in use), it reloads the HA page when you tap on it. I don’t know why it would do this, and it’s pretty frustrating because it triggers the reload right when you are about to tap on something.
The first one I can ignore, as it works well enough. I think the second is an issue when these are installed in a bedroom, because I can’t control the brightness level and using something like Wallpanel (the HACS frontend module, not the Android app) can only make the screen black, not turn out the backlight.
Also, it seems to persist in reloading using a white background, which is extra jarring.
I can’t find any controls to prevent it from reloading.
Yep, I not found way to auto dim brightness yet.
I don’t use standby mode because of reload after woke up.
For me ideal be dim brightness to 10% when not used and return to last settings if movement detected.
I have a lot more experimenting to do, and there’s an issue with getting authenticated, but the screen’s API is pretty decent. Not everything is documented, but you can watch the RESTful commands when setting properties via the web UI.
For example, you can POST this data to /Device/DeviceOperations to make the screen enter standby:
It still reloads the content when using that command, but it might be worth it to put the screen to sleep manually based on time and wake it based on time for power saving. This could also be used as a hack to force the panel to reload.
There are similar commands to set the brightness level, or to set the automatic brightness levels.
This was just some basic experimenting I did tonight while getting ready for the North America eclipse tomorrow, so hopefully it inspires someone else to look into the API more.
Has anyone had any luck with a TWS-560p-b-s? I’ve upgraded the firmware as posted earlier but there doesn’t seem to be an option to browse to a URL…maybe I’m missing something. There is no option for EMS under Applications - Just User Project, Default, Home and Appspace.
I’d been keen on the ‘program’ for the web browser if you’re willing to share. I want to create a dashboard in HA for my tsw-560p to control a couple of things
Hey Paul, I just tested a 560 non p and found the same, converted it to a p model using the text console command “lcdorientation portrait” and same thing in p mode.
I loaded my browser app to it, and I can browse some websites but I can’t get the HA login screen to work… Might work with a less complex dashboard ?
I can end the vtz file when I get home !
P.s. the web browser program isn’t great, it will go back to crestron website on power loss
Ahhh damn! Okay, well thanks for trying it. I’m only planning on using it a simple dashboard with a couple of buttons for a light and some A/V related buttons (Projector on/off or run script etc.) so, maybe. Shoot it over when you get a chance and I’ll have a play. I just don’t have the programming software to make my own…yet.
Like others, just picked up an old Crestron unit at recyclers. Anyone know if the TSW-750 uses the same firmware as above? There aren’t any projects or anything on the unit and I can’t seem to load anything to the panel without Crestron Toolbox. Just need a way to get it my HA dashboard URL…
Would love to get my hands on that project for running a URL if you have it. The panel I picked up doesn’t have anything I can load through the panel and the web GUI says access denied. I can however FTP to it…
Just got a Crestron TSW-1060. But I don’t know what to do with it. I’m new to HA, just set it up as a Docker on my Qnap device. How do I get them to talk together? Thanks,
I just started using a 1060 as a dashboard via the EMS app. So far, so good. Reloading on wake from sleeping state does force a reload (which is old-android-device slow as expected) so I’ve instead just let it run. It doesn’t really hurt anything, these panels are designed to be pretty reliable and if it quits, I’ll just get another $30 unit. I assume the camera and microphone on the panel itself are useless without an actual crestron program/processor?
