New version (0.4) on HACS / Github for download. A few people on the forums are having problems with their cars going offline unexpectedly, so the component now exposes an online state to allow you to monitor this and take action:
Ah, I assumed it was the same app.
I prefer not to shared my credentials, and I doubt I have the skill to reverse engineer it.
So I will stick to using the cupra app for now.
Thanks for your effort!
No problem, completely understand!
Small update (v0.5) to fix a bug with binary_sensor.cupra_born_door_lock_status
not working properly, and adding support for dutch translation to the component setup.
If anyone wishes to add translation in their own language (which is mostly centred around the component setup), please submit a PR!
Hi Mitch,
Nice looking - would it be possible for you to share the code for this?
Thanks for all the hard work, the add-on nowadays works flawless as long as the API is working.
A bonus thing to add would be support for ABRP, like VWsFriend does: GitHub - tillsteinbach/VWsFriend: VW WeConnect visualization and control
Any ideas if this is possible?
Interesting. ABRP is not something I’ve ever used myself.
How would you expect this to work? Click a button and push the location / SoC data into ABRP?
Ideally I wouldn’t want to push any button, just generate the ABRP token and set the integration up to send/passthrough the SoC information to ABRP.
Like VWsfriend: “…supports sending its data to ABPR out of the box. You just have to generate a user-token in ABRP and configure it for your car in the UI. Connecting VWsFriend to ABRP enables you to use the current SoC, position, parking and charging state (feature availability depends on your car!) when planning routes in ABRP”.
This saves us from the need to use an OBD2 dongle or a Tronity subscription to fully use ABRP with relevant battery SoC info available. Quite neat
square: false
columns: 1
type: grid
cards:
- square: false
columns: 1
type: grid
cards:
- type: picture
image: local/images/995.png
card_mod:
style: |
ha-card
{border-style: none;
- square: false
columns: 2
type: grid
cards:
- type: custom:mushroom-entity-card
entity: sensor.cupra_born_range_in_kilometers
fill_container: false
icon: ''
icon_color: purple
entity: sensor.cupra_born_odometer_in_kilometers
- square: false
columns: 2
type: grid
cards:
entity: sensor.cupra_born_state_of_charge
icon_color: teal
entity: sensor.werk
icon: mdi:office-building-marker-outline
icon_color: deep-purple
- square: false
columns: 2
type: grid
cards:
entity: sensor.cupra_born_climatisation_state
entity: sensor.charge_finish_time_klimatisering
icon: mdi:home-clock-outline
- square: false
columns: 2
type: grid
cards:
entity: sensor.cupra_born_charge_power
icon_color: red
entity: sensor.cupra_born_charge_rate
icon: mdi:ev-plug-type2
icon_color: orange
- square: false
columns: 2
type: grid
cards:
icon: mdi:ev-station
icon_color: blue-grey
entity: sensor.batterij_kwh
entity: sensor.charge_finish_time_laden
name: Laden klaar om
icon: mdi:battery-clock
- square: false
columns: 3
type: grid
cards:
- type: custom:mushroom-lock-card
entity: binary_sensor.cupra_born_overall_status
layout: vertical
primary_info: name
secondary_info: state
icon: mdi:car-door
entity: binary_sensor.cupra_born_trunk_lock_status
fill_container: true
layout: vertical
primary_info: name
entity: binary_sensor.cupra_born_lights_status
layout: vertical
square: false
columns: 1
type: grid
cards:
- type: custom:mushroom-title-card
title: Deuren
- square: true
columns: 4
type: grid
cards:
entity: binary_sensor.cupra_born_door_front_left_open_status
layout: vertical
entity: binary_sensor.cupra_born_door_front_right_open_status
layout: vertical
entity: binary_sensor.cupra_born_door_rear_left_open_status
layout: vertical
entity: binary_sensor.cupra_born_door_rear_right_open_status
layout: vertical
- square: true
columns: 4
type: grid
cards:
entity: binary_sensor.cupra_born_door_front_left_lock_status
layout: vertical
entity: binary_sensor.cupra_born_door_front_right_lock_status
layout: vertical
entity: binary_sensor.cupra_born_door_rear_left_lock_status
layout: vertical
entity: binary_sensor.cupra_born_door_rear_right_lock_status
layout: vertical
- square: false
columns: 3
type: grid
cards:
title: Ramen
- square: false
columns: 4
type: grid
cards:
entity: binary_sensor.cupra_born_window_front_left_open_status
layout: vertical
layout: vertical
layout: vertical
layout: vertical
- square: false
columns: 1
type: grid
cards:
title: Verwarming
- square: false
columns: 4
type: grid
cards:
entity: binary_sensor.cupra_born_front_window_heating_state
layout: vertical
primary_info: name
entity: binary_sensor.cupra_born_rear_window_heating_state
layout: vertical
entity: binary_sensor.cupra_born_zone_front_left_enabled
layout: vertical
icon: mdi:heat-wave
icon_color: red
primary_info: name
entity: binary_sensor.cupra_born_zone_front_right_enabled
icon_color: red
layout: vertical
icon: mdi:heat-wave
Hi all,
Is there anything specific I need to do, in order to get all the sensors?
I don’t see the sensors for the doors and windows? Do I need to enable anything in the car before I can do that. When I open the app I am able to see if a door or window is open, but not in Home Assistant.
Hoi Mitch,
Trying to figure out where to put your code snippet into my raw configuration. I have created a new tab/view that I call ‘Test’. It’s completey blank still so all it has now is
- title: Test
path: test
badges: []
cards: []
So somewhere your code should be pasted into this. Can you help? (NB. I already noticed some local paths to images in your code, so that is not going to work, but I’ll figure that out later).
Thanks/Dank.
You have to install some hacs cards en themes
ios-dark-mode-blue-red
custom:horizontal-layout
This is mine raw configuration
- title: Cupra Born
path: cupra-born
icon: mdi:car-electric
type: custom:horizontal-layout
theme: ios-dark-mode-blue-red
badges: []
cards:
- square: false
columns: 1
type: grid
cards:
- square: false
columns: 1
type: grid
cards:
- type: picture
card_mod:
style: |
ha-card
- square: false
columns: 2
type: grid
cards:
icon: ''
icon_color: purple
- square: false
columns: 2
type: grid
cards:
icon_color: teal
entity: sensor.werk
- square: false
columns: 2
type: grid
cards:
- square: false
columns: 2
type: grid
cards:
icon_color: red
icon_color: orange
- square: false
columns: 2
type: grid
cards:
- square: false
columns: 3
type: grid
cards:
layout: vertical
primary_info: name
icon: mdi:car-door
layout: vertical
primary_info: name
layout: vertical
- square: false
columns: 1
type: grid
cards:
title: Deuren
- square: true
columns: 4
type: grid
cards:
layout: vertical
layout: vertical
layout: vertical
layout: vertical
- square: true
columns: 4
type: grid
cards:
layout: vertical
layout: vertical
layout: vertical
layout: vertical
- square: false
columns: 3
type: grid
cards:
title: Ramen
- square: false
columns: 4
type: grid
cards:
layout: vertical
layout: vertical
layout: vertical
layout: vertical
- square: false
columns: 1
type: grid
cards:
title: Verwarming
- square: false
columns: 4
type: grid
cards:
layout: vertical
primary_info: name
layout: vertical
layout: vertical
icon: mdi:heat-wave
icon_color: red
primary_info: name
icon_color: red
layout: vertical
icon: mdi:heat-wave
Hey,
im new to HA, so be nice
I was able to set up the Cupra Connect Integration on my HA, it works perfectly fine.
Now id love to give @_Mitch07 s Configuration a shot, since it look visually very good!
But im confused on where exactly i need to put that raw configuration in to make use of it.
Is ur config a fully dashboard with all diverse cards included?
Thanks!
Furkan
In one of your views in Lovelace, click the overflow menu in the upper right (three dots), click Configure UI, click the dots again, then click Raw config editor
Hey,
for me it was:
Lovelace → 3 Dots → Edit Dashboard → 3 Dots → Raw Configuration Editor
I dont if thats the right spot, but when i try to copy paste ur config, i get this error when saving:
Unable to parse YAML: YAMLException: bad indentation of a mapping entry (2:9) 1 | - title: Cupra Born 2 | path: cupra-born -------------^ 3 | icon: mdi:car-electric 4 | type: custom:horizontal-layout
Furkan
It’s not a matter of deploying the code and you’re done.
You need to make sure everything is aligned properly. I can’t help you with that.
If you have no experience in this, it might be an idea to search on “home assistant create dashboard” via Google and look further from there.
Aight, thanks!
The eagle-eyed will have noticed 0.6 is out. Nothing very exciting, but it now cohabits a bit nicer with the VW integration so for those who have both cars, they can use both integrations. It also now reports if the hood (bonnet, for UKers) is open in case that’s something you really want to know about.
All working fine with the latest 2023.8.x release of HA too.
Seems that the Cupra WebAPI is completely down today. Neither the intregration nor the smartphone app is working.
HA log shows:
2023-08-16 WARNING (SyncWorker_14) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate has expired (_ssl.c:1002)'))'
To my mind VW or SEAT did forget to renew the ssl certificate. Rookies.
