Updated version (0.7) pushed out in beta on HACS. This fixes an issue with some newer cars which were not updating their door / lock / window status correctly since the summer when the API was tweaked by VW. I would appreciate it if anyone wanted to install this and report back as I obviously don’t have a fleet of different age cars with which to test this!
Thanks to @_Mitch07 for helping me out with testing it on his car, which was not updating correctly but is working again now
Hi, I was able to install the integration without any Problems via HACS. After the installation I didn’t find any possibility for entering username and password and I don’t find the integration in HA I just see it in HACS. I’ve tried to uninstall and install it multiple times without any success. Does anybody have any suggestions for me?
Thanks, Andreas
I’m new, have installed a green+hacs+this cupra plugin: very nice, impressed.
I would like to setup an automation “if plugged int at 22:00 then start charging”, have found the trigger, but the only actions available are “Set value for CUPRA Born Target State Of Charge” and “Set value for CUPRA Born Climate temperature”.
Good evening. Just downloaded this integration and installed via HACS. All files seem to be where they should be. However, I don’t see anything except the “Cupra WeConnect Update” service.
The well written instructions say "After that enable the integration on the integration page in Home Assistant with your e-mail and password that you use to login into the app. "
But I can’t find anywhere to enter my login details.
Any ideas what can be wrong here?
Once you’ve installed the integration with HACS and rebooted HA, go to Settings → Devices and Services → Add Integration. Search for “Cupra” and follow the instructions.
Hi, I have Cupra integration and has been working fine up until midlle of last week where it errors on sending a start charge command. Everything else is working in way of updates and command. ( I have raised this on Github )
The log shows this entry
ERROR (SyncWorker_6) [custom_components.cupra_we_connect] Failed to send request to car - Could not control charging (400)
I can figure out where the root cause of the issue is. Has anyone experienced this and know where to look for troubleshooting further?
