I moved my configs over to my new HASS.IO installation. All is cool but i am getting the below errors for all my Foscam 9821. My Foscam 8910 using the MJPEG component is running fine. What gives? Any guidance would be appreciated.
Keep in mind that shell commands run in the account of the HA user. If you moved from a standard HA install to HASS.io, chances are your user account for HA changed as well (IDK for sure as I don’t use HASS.io). So you may need to add the HASS.io user to sudoers list.
Ahh no dice, the user changed to root of course. Plus the other curl commands used to control the camera are still working. I think the issue falls in the grep command itself but am not sure how to fix it.
