Work perfectly
thank you so much
Same here, not working properly on my iPhone, but this issue does not appear on my ipad airā¦
Hi just wondering is there an easy way to show both current weather and todays forecast?
I have been using the Overview dashboard with the standard cards, but now I want to add this custom card. I placed the js and icons in the folders www/custom-lovelace/weather-card and added this to configuration.yaml:
lovelace:
resources:
- url: /local/custom-lovelace/weather-card/weather-card.js
type: module
After restarting, I went to Overview, edit, and selected manual. Here is what I entered there and the result:
But there is a file /config/www/custom-lovelace/weather-card/weather-card.js Why canāt HA find and use it? Thanks for any help.
Clear the cache browser
I like this card and Iāve been using it for quite a while⦠but I too miss a few features from the Dark Sky card (red boxes):
did you find a solution to use tap_action?
My Raspberry PIās CPU thanks you!
Hey all, I am trying to output the hourly forecast, but it shows same time for different dates:
Here is my config:
type: custom:weather-card
entity: weather.patriarha
forecast: true
hourly_forecast: true
details: false
current: false
number_of_forecasts: 8
Maybe its the data itselfā¦not sure. A way to check:
Go to UI->DevTools->Services and enter:
service: weather.get_forecasts
type: hourly
entity_id: weather.patriarha
For your hourly forecast items you should see something like ādatetimeā in each item but the hours should be incrementing:
datetime: "2024-03-12T14:00:00-04:00"
datetime: "2024-03-12T15:00:00-04:00"
Thanks for the tip. It is showing sequential hours correctly:
weather.patriarha:
forecast:
- condition: cloudy
datetime: "2024-03-12T20:00:00+00:00"
temperature: 6.3
- condition: cloudy
datetime: "2024-03-12T21:00:00+00:00"
temperature: 5.1
- condition: cloudy
datetime: "2024-03-12T22:00:00+00:00"
temperature: 5.2
Maybe try the following ā¦change the hourly_forecast to forecast_type
current: false
details: false
forecast: true
forecast_type: hourly
TL;DR I switched to the locally hosted version of the card and it all works now!
Your suggestion gave me an idea to look at the code. I realized that my version of the card is different than the one in GitHub. I was using the CDN served file which was a very old version of the card.
So, thank you so much for helping me resolve the issue @wmaker
Iāve been using this card for a long long time. After last HA update (to 2024.4.0) non of my configured weather sources does not work witd daily forecast.
My config:
automation:
- id: get_home_weather_forecast
mode: restart
alias: get_home_weather_forecast
- platform: time_pattern
hours: /1
- service: weather.get_forecasts
entity_id:
- weather.metno
type: daily
Response:
weather.metno:
forecast:
- condition: rainy
datetime: "2024-04-04T10:00:00+00:00"
wind_bearing: 223
temperature: 16.9
templow: 11.2
wind_speed: 17.3
precipitation: 3.9
humidity: 54
- condition: cloudy
datetime: "2024-04-05T10:00:00+00:00"
wind_bearing: 221
temperature: 18.5
templow: 7
wind_speed: 18
precipitation: 0
humidity: 65
- condition: cloudy
Lovelace config, I remove card_mod part only:
- type: 'custom:weather-card'
entity: weather.metno
details: false
forecast: true
hourly_forecast: false
number_of_forecasts: '5'
Result on the dashboard: ![]()
Any hint what I am doing wrong? Pls
I think this is due to the fact the forecast has been removed from the attributes and you need to get it with the get_forecasts service. Also some cards I use are not working with forecasts anymore. Think we have to wait for the developer of the card to update this.
FYI, this change has been announced some time ago but seems like not every developer has integrated this. Also see the weather info in breaking changes of the release notes.
Question is, how to implement get_forecasts response to the card.
From my point of view, all custom weather cards does not work with forecast anymore (after last HA update.
Default weather-forecast card is one and only working but not able to apply card-mod
Waiting is probably the only option
Edited:Solved by the developer
