Thanks a lot!! You saved the day!!
Now, I will install the A02YYUW in the water tank, let’s see if it works without problems of condensation.
Regards
Jordi
Regards
Jordi
How did that go for you @Despertaferro ?
Well, I had some troubles with the readings, highly random and with a lot of fluctuations. I still have to check thoroughly the cables and try again. I will chime in with news once I figure out what is going on. I guess that some of the soldering I did is defective, or maybe too long cables adding too much noise, go figure…
Two days and much frustration later:
Use Fileeditor
add file: /config/esphome/A02YYUW-Sensor.
#include "esphome.h"
class MyCustomSensor : public PollingComponent, public Sensor {
public:
MyCustomSensor() : PollingComponent(1000) {}
void setup() override {
// Configure the UART for communication with A02YYUW-Sensor
Serial.begin(9600);
pinMode(echo_pin_, INPUT);
pinMode(trigger_pin_, OUTPUT);
void update() override {
// Trigger the sensor to send a pulse
digitalWrite(trigger_pin_, LOW);
delayMicroseconds(2);
digitalWrite(trigger_pin_, HIGH);
delayMicroseconds(10);
// Read the pulse duration and calculate the distance
long duration = pulseIn(echo_pin_, HIGH);
float distance = (duration / 2) / 29.1;
// Publish the distance as a sensor reading
publish_state(distance);
private:
const uint8_t echo_pin_ = 16; // YOUR PIN HERE
const uint8_t trigger_pin_ = 17; // YOUR PIN HERE
And here the code snipped From EspHome-Device:
esphome:
friendly_name: Water-Sensor
includes:
- A02YYUW-Sensor.h
esp32:
board: node32s
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "YOUR KEY HERE"
ota:
password: "YOUR PW HERE"
wifi:
ssid: !secret wifi_ssid
# Static IP
manual_ip:
static_ip: 192.168.178.100
gateway: 192.168.178.1
subnet: 255.255.255.0
ap:
ssid: "Water-Sensor Fallback Hotspot"
- platform: custom
lambda: |-
auto my_sensor = new MyCustomSensor();
App.register_component(my_sensor);
return {my_sensor};
sensors:
name: "Tank Water Level"
unit_of_measurement: "cm"
accuracy_decimals: 0
It´s not the final version, but its works!
Hope it helps and gives you a good starting point.
p.s.
Best regards
Hi guys,
I am playing with that same sensor (A02YYUW) in ESPhome, too. I am currently using @taraant custom component. As it is nicer code then the one I glued together.
But, I find annoying to poll the sensor every 100 ms as I need the info, let’s say every minute. And you can not make the update interval bigger, as the UART apparently have a buffer. So, if I change the polling interval, I get to read the data from buffer, but only 4 bytes at a time. AKA, I get the data from now, much later in a future.
Do anybody know, the proper approach to this? I was thinking about, serial.begin() in .h file. That might help to solve that issue. Or is there another “proper way” to do this?
Bonjour j’ai aussi un capteur A02YYUW avec carte wemos d1 et je arrive pas à avoir de valeurs dans home assistant avec esp home
Pouvez vous m’expliquer quel code yaml avez vous modifier avec file editor ?
Bonjour j’ai le même projet avec le capteur ultrason je ne comprend pas les codes ci dessus ou faut il les installer ? Config/esp home/?
Hi Fantomaz,
esphome:
includes:
- A02YYUW-Sensor.h
Thanks @Equilibrium for the custom component - however I am having some trouble with it, as it will only output a distance of 16cm. Is this still working for you?
[14:13:41][D][sensor:110]: 'Tank Water Level': Sending state 16.08247 cm with 0 decimals of accuracy
[14:13:42][D][sensor:110]: 'Tank Water Level': Sending state 16.04811 cm with 0 decimals of accuracy
[14:13:43][D][sensor:110]: 'Tank Water Level': Sending state 16.04811 cm with 0 decimals of accuracy
[14:13:44][D][sensor:110]: 'Tank Water Level': Sending state 16.08247 cm with 0 decimals of accuracy
[14:13:45][D][sensor:110]: 'Tank Water Level': Sending state 16.08247 cm with 0 decimals of accuracy
So i was finally able to get the A02YYUW sensor working with UART , here is the below code. Following above code i was also getting the same readings.
I am using the sensor with ESP32 so using the hardware serial at GPIO 16/17
below is the code for the A02YYUW.h file
#pragma once
class A02YYUWSensor : public esphome::Component, public esphome::sensor::Sensor {
public:
void setup() override;
void loop() override;
private:
HardwareSerial serial_ = HardwareSerial(2); // Use the second hardware serial port (GPIO16=RX, GPIO17=TX)
uint8_t buffer_[4] = {};
float distance_ = 0.0f;
void A02YYUWSensor::setup() {
// Set up the serial port for the UART communication
serial_.begin(9600, SERIAL_8N1, 16, 17); // baud rate, parity, RX pin, TX pin
void A02YYUWSensor::loop() {
// Read the UART data from the sensor
while (serial_.available()) {
if (buffer_[0] == 0xFF && serial_.readBytes(buffer_ + 1, 3) == 3) {
uint8_t sum = (buffer_[0] + buffer_[1] + buffer_[2]) & 0xFF;
if (sum == buffer_[3]) {
uint16_t distance_raw = (buffer_[1] << 8) | buffer_[2];
if (distance_raw > 30) {
distance_ = static_cast<float>(distance_raw) / 10.0f; // Convert to cm
} else {
distance_ = 0.0f; // Below the lower limit
break; // Successfully parsed a valid UART frame, exit the loop
} else {
buffer_[0] = serial_.read(); // Invalid header, discard and try again
// Update the sensor with the current distance value
publish_state(distance_);
// Your code for processing sensor data goes here
below is the code for the yaml file
esphome:
platform: ESP32
board: esp32dev
includes:
- A02YYUW-Sensor.h
# Enable logging
logger:
level: DEBUG
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: "xxxxxxxxxxj"
password: "xxxxxxxxxxxx"
ap:
ssid: "xxxxxxxxxxxx"
password: "xxxxxxxxxxxxxxxxxx"
uart:
rx_pin: 16
tx_pin: 17
baud_rate: 9600
- platform: custom
lambda: |-
auto a02yyuw_sensor = new A02YYUWSensor();
App.register_component(a02yyuw_sensor);
return {a02yyuw_sensor};
sensors:
- name: "Tank Level"
unit_of_measurement: cm
accuracy_decimals: 1
icon: mdi:gauge
just try this one and update if this holds good for you too.
Thank you for this, it works perfectly
Is there a way to reduce the interval it stores in ESPHOME please?
Would it be a case of header file to only publish every xx loop, instead of constantly?
I played with the sensor with some arduino code (not in ESPHOME) and it has a default sensing delay of 100mS. When i increased that , it didnt read properly so I am assuming, it must run/sample at that frequency to function correclty?
I am just consious about how often its battering ESPHOME with readings.
Code from @vishwamittrabhardwaj worked but with no update interval it updated every 100ms so I’ve added PollingComponent into the code
#pragma once
class A02YYUWSensor : public PollingComponent, public Sensor {
public:
A02YYUWSensor() : PollingComponent(4000) {}
void update() override;
private:
serial_.begin(9600, SERIAL_8N1, 44, 43); // baud rate, parity, RX pin, TX pin
} else {
} else {
void A02YYUWSensor::update() {
Sorry if there mistakes, first time understanding C++ code
I used Update and Loop at the same time.
Every 4000ms publish_state is sent with the latest distance from loop.
If you just use Update then it’s the older distance that is in a queue
I also added Quantity and Percentage of water to use in a tank into the yaml file:
uart:
rx_pin: GPIO44
tx_pin: GPIO43
baud_rate: 9600
- platform: custom
lambda: |-
sensors:
icon: mdi:gauge
name: "Tank Quantity"
icon: "mdi:water"
unit_of_measurement: "l"
lambda: return ((((id(level_cm).state)-7)-89)/89)*-826;
# 7: Distance from sensor and full water
# 826: Numbers of liters of the tank
# 89: Max distance from top to bottom water
update_interval: 1s
filters:
- clamp:
min_value: 0
max_value: 826
name: "Tank Percentage"
icon: "mdi:water"
unit_of_measurement: "%"
lambda: return ((((id(level_cm).state)-7)-89)/89)*-100;
update_interval: 1s
filters:
- clamp:
min_value: 0
max_value: 100
text_sensor:
icon: "mdi:gauge-full"
lambda: |-
if (id(percentage).state >= 100) {
return {"Full"};
else if (id(level_cm).state >= 89) {
return {"Empty"};
else {
return {"Filling"};
update_interval: 1s
You need to change the RX and TX pin, mine are from an ESP32-S3
Official integration was added in 2023.12.0 by @TH-Braemer
I’m trying to get the A02YYUW sensor working on a Wemos D1 mini but I’m not successful. Tried every suggestion in this topic, nothing works for me.
The docs are not very helpful either. Any help would be greatly appreciated.
never mind, I got it to work.
I dont get it to work either? How did you do it?
I’m not using it any more, but this is the code I used in my yaml file:
(I had it connected to a D1 mini)
uart:
rx_pin: D4
baud_rate: 9600
- platform: a02yyuw
unit_of_measurement: 'm'
filters:
- multiply: 0.001
- throttle: 5s
- heartbeat: 5s
- quantile:
window_size: 7
send_every: 4
send_first_at: 3
quantile: .9
- debounce: 0.1s
Hello!
i get this?
Failed config
sensor.a02yyuw: [source /config/esphome/avstand.yaml:41]
Platform not found: ‘sensor.a02yyuw’.
platform: a02yyuw
unit_of_measurement: m
filters:
- multiply: 0.001
- throttle: 5s
- heartbeat: 5s
- quantile:
window_size: 7
send_every: 4
send_first_at: 3
quantile: 0.9
- debounce: 0.1s
What do i have to add?
i got it working!! I hade the RX TX shifted…
Thank you! Fore your answer…
/Micke
