The key in the dict need to match the state, so "None": "Some translated string"
And the filename needs to be domain.langcode.json
(sensor.nl.json)
(sensor.nl.json)
Maybe this component is a good example: https://github.com/home-assistant/home-assistant/tree/dev/homeassistant/components/adguard
I think you need a file ‘strings.json’ and then corresponding translation-files, en.json, nl.json, etc.
But, after a quick look at the details, I’m not sure how the text in strings.json
connects to the py-files…
Apparently, you need to follow this: https://developers.home-assistant.io/docs/en/internationalization_backend_localization.html
Look at the chapters States and Configuration Flow Localisation for details.
But, maybe you already got up to there?
Nice component, thank you Pippyn!
In my town we have collector Spaarnelanden. I can get a sensor for GFT right away, but not for “Duobak PBD/Papier”: https://afvalwijzer.spaarnelanden.nl/afvalstroom/1. What’s the resource name I should use for this fraction? I’ve tried different names from the github page and a number of my own guesses, but I gave up.
Would it be helpful to make an additional sensor that returns a list of the supported resources names for a collector?
What is your config? do you have an address for me to test with?
This is my config:
- platform: afvalbeheer
wastecollector: Spaarnelanden
resources:
- gft
- duobak
postcode: xxxxyy
streetnumber: zzz
upcomingsensor: 1
dateformat: '%d %b'
# dateonly: 0 (optional)
# name: "" (optional)
# nameprefix: 1 (optional)
builtinicons: 1
dutch: 1
A random address that has the same collector and fractions: 2014HJ, 314.
Thanks for looking into this!
I’ve found the issue. There is a bug in my code, the fraction is renamed to “Papier”. I will write a fix, but for now you can add “papier” as a resource.
Thank you Pippyn, this works for me!
Update to version 2.5.5 and change the fraction to “duobak”. And please let me know if it works for you.
Is it possible that you create a changelog with breaking changes for the releases on Github? After the latest few patch-updates for this component, my UI and automations stopped showing or reporting on trash-days, because of name-changes in the component;
State ‘none’ changed to ‘geen’ a few versions ago, and now the names of my sensors changed as well. I’ve noticed that the release was titled: 'Support for name… ', but it did not mention that this would change the sensornames if I didn’t add that to the config.
Yes, this works - thanks once more!
Good point. I will do in the future! Sorry for the inconvenience.
Hi there,
would it be possible to add the Avri?
https://www.avri.nl/inwoners/afval/afvalinzameling/afvalkalender-2019/
that would be great, you can find the avri pick-up days on www.deafvalapp.nl.
Unfortunately I also do not know how I get this in home assistant.
Example zip code and house number: 6658GT 65
Followed all the steps, when adding the sensor:
wastecollector: Circulus-Berkel (required)
resources: (at least 1 required)
- restafval
- gft
- papier
- pmd
postcode: AAAA00 (required)
streetnumber: 5 (required)
upcomingsensor: 1 (optional)
dateformat: '%d-%m-%Y' (optional)
name: '' (optional)
builtinicons: 0 (optional)
dutch: 0 (optional)
I get this config error:
can not read a block mapping entry; a multiline key may not be an implicit key at line 165, column 13:
Any idea?
indentation error. Use this;
resources:
- restafval
- gft
- papier
- pmd
postcode: AAAA00
streetnumber: 5
upcomingsensor: 1
dateonly: 0
nameprefix: 1
builtinicons: 0
dutch: 0
does not help
after restart I get this:
Error loading /config/configuration.yaml: while parsing a block mapping
in “/config/sensors.yaml”, line 154, column 5
expected , but found ‘’
in “/config/sensors.yaml”, line 162, column 38
line 154= - platform: afvalbeheer
line 162= dateformat: ‘%d-%m-%Y’
Remove all the (), eg ```
(required)
I’m trying to use the ophaalkalender integration, but I don’t get any information in the sensor.
When I go to the ophaalkalender.be site, I also don’t get any info for my address… Does anyone know why it isn’t giving information for Antwerp? When I try the recycle app it finds the dates…
Hi, thanks for the rova component. But it does not work for me. A colleague of mine who is also experimenten with HA also tried the rova component, but he gets the same issue.
the issue:
Here is my log:
Log Details (ERROR)
Tue Jan 21 2020 21:05:05 GMT+0100 (Midden-Europese standaardtijd)
Update for sensor.rova_afvalkalender_gft fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 279, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 461, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/config/custom_components/afvalbeheer/sensor.py", line 362, in update
self.data.update()
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 240, in wrapper
result = method(*args, **kwargs)
File "/config/custom_components/afvalbeheer/sensor.py", line 260, in update
response = requests.get(url).json()
File "/usr/local/lib/python3.7/site-packages/requests/models.py", line 897, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/local/lib/python3.7/site-packages/simplejson/__init__.py", line 525, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 370, in decode
obj, end = self.raw_decode(s)
File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 400, in raw_decode
return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
This is my config in the sensors.yaml:
wastecollector: Rova
resources:
- restafval
- gft
- pmd
postcode: 8014kd #(a postal code in rova area)
streetnumber: 48
upcomingsensor: 1
dateformat: '%d %b'
