Custom component Afvalbeheer - Support for multiple waste collectors
running your beta version all day, no issues so far.
Also here it works without any problem so far, thanks for the quick modification Pippyn!
No problems either.
I can’t find what I’m doing wrong here …
I installed the vertical-stack-in-card but unfortunately the image doesn’t flash with your code either.
Support for RecycleApp is added in version v4.6.0
Just updated to 4.6 and my sensors are working again with RecycleApp!
I did have to change “restafval” to “restfractie” to get that info now.
Fixed in v4.6.1
Install the new version and use restafval again
Thanks for the quick fix. It’s working perfectly now.
I know what I did wrong, I forgot to install the card-mod.js as a module.
Now the flashing option works
Hi, i’m using the new ‘ophaalkalender/RecycleApp’ and it works great but i cant get the date for the ‘green waste’ (" ‘snoeihout’: WASTE_TYPE_BRANCHES "). I tried snoeihout and groenafval but i din’t work. What should i use for this sensor.
try takken
Available waste types: grofvuil, papier, plastic, pmd, restafval, takken
The fractions could be different for every region. You could use this option to see what fractions are available for you.
Yes, thanks for the help. Works like a charm
I had been using this with succes for ophaalkalender.
However i noticed its changed and had to switch to RecycleApp
So i did, and i adjusted my sensors too.
But now the state of my sensors say they are unknown…
any idea?
edit: i see streetnumber now is a must… i added it too, but still unknown
the sensor name is also different and starts with sensor.recycleapp_xxxx
streetnumber was always a must. Can you share your config?
I did change that
Thats strange, cause it worked without it (using ophaalkalender)
I’m living in belgium (knokke-heist)
Here’s the code
  - platform: afvalbeheer
    wastecollector: RecycleApp
    resources:
      - restafval
      - papier
      - pmd
    postcode: !secret recycleapp_postcode
    streetnumber: !secret recycleapp_streetnumber
    streetname: !secret recycleapp_streetname
    dutch: 1
    dateformat: '%d-%B'
    dateonly: 0
    dayofweek: 0
    builtinicons: 0
    upcomingsensor: 1
I will also need an address from your neighborhood.
send via pm
