Nice i got this working, Meerlanden collects paper but in my area is this done true the local sportclubs. And therefore my street is not on the wastecalendar. The main road is, so i added that address
i am quite new to HA but got it all up and running and was now using this sensor plug in which i really like
i created the config section and my config points to Circlus-Berkel, restarted HA and i see the sensors all available in entities for Paper, GFT etc.
However, i dont seem to get an update. Days until is showing a “-”" see also the image
how do i know the API is working, or how can i test the connectivty?
i am trying to send you DM in this forum, and i checked everything but i cant seem to find how to send DM directly… perhaps because i am still as newbee stage in this forum? very sorry for this incovenience, hope you can help me
Hi, Probably me being stupid, but I’m new to HA. Have a afvalbeheer sensor up and running but can’t find how to create the card to show like its shown in the example screenshot on github…
Now that I think about it, it shouldn’t make any difference. It’s most likely an indentation error.
Could you post the config again, but this time in a code block
this is the only logging i see: that reffers to it :
Logger: homeassistant.loader
Source: loader.py:783
First occurred: 2:56:12 PM (1 occurrences)
Last logged: 2:56:12 PM
You are using a custom integration afvalbeheer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
