I installed afvalbeeheer component years ago and regularly update when I notice in HACS. However I now notice that 2 key sensors of this integration are not available anymore; sensor.gad_morgen and sensor.gad_vandaag.
Have these been removed from the integration? Any chance to get them back?
@Pippyn forgot to post solution. It seems they have been renamed from dutch to english. So now they are sensor.gad_today vs sensor.gad_vandaag. I guess this change has been made in the past and only found out now due to finally updating via HACS
2022-12-07 12:11:19.776 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration afvalbeheer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
When I click on the entity in the layout I get this message
Deze entiteit is niet meer beschikbaar vanuit de afvalbeheer integratie. Wanneer de entiteit niet meer in gebruik is, kan deze vanuit de instellingen verwijderd worden.
I would like to be able to access via my mushroom interface on the day that the container has to be on the road by means of a chip card (only the icon) to see which container should be placed on the road. Does anyone here have an idea how to get this done?
For one of the other reason I can’t seem to find a solution to print the custom icons.
I’m quite new to Home Assistant, so that might be the cause
Below is the code I’ve put into my configuration.yaml file, it works as designed, but in my entities, I don’t see the integration-specific icons. Any help would be appreciated!
The quotes in the end are a copy-paste issue I guess
I’ve adapt the dateformat quotes. But images are still not loading in my config. Maybe I’m missing an integration or some other dependency?
