The HACS is working great, but I am not sure there is an option to send on Android app notifications from Home Assistant App alerting me to put the paper out for tomorrow, did someone already configure that?
@Pippyn I love your component and I use it to remind me in different ways. But now my muniicipality has decided to move to a different collector: RD Maasland. Is it possible to add support for this collector? Or is this a collector that is already there but under a different name? I couldn’t find any info about their API.
0000 is off course my zipcode, and ABCD is replaced with my city and streetname.
I’ve tried replacing “builtiniconsnew: 1” with “builtinicons: 1”, but nothing changes. I’ve restarted, HA has been upgraded since I started playing around with it, it keeps showing up like this:
Afvalbeheer v6.0.0 Released - Major Config Flow Update!
Hi everyone!
I’m excited to announce the release of Afvalbeheer v6.0.0, bringing some major improvements to the popular Dutch and Belgian waste collection integration!
What’s New in v6.0.0
Config Flow UI Support
The biggest change in this release is the addition of Config Flow support! You can now configure the integration entirely through the Home Assistant UI:
Step-by-step wizard for easy setup
Visual waste collector selection from 50+ supported collectors
Interactive address configuration with validation
Resource selection with checkboxes for different waste types
Advanced options configuration through the UI
Important: YAML configuration is now deprecated and will be removed in a future version. The integration will automatically import existing YAML configurations, but please migrate to the UI configuration for future updates.
Enhanced Architecture
Complete refactor of sensor setup logic
Improved error handling and validation
Better entity cleanup when configuration changes
More robust data management
Improved User Experience
Clear validation messages for invalid configurations
Better support for special cases (Limburg.NET, RecycleApp requirements)
Streamlined entity naming and management
Still Supports All Your Favorite Features
50+ waste collectors across Netherlands and Belgium
Sensor entities for each waste type
Calendar entity showing all upcoming collections
Upcoming sensors (today, tomorrow, next upcoming)
Custom date formatting and display options
Built-in icons (including new icon set)
Dutch translation support
Custom waste type mapping
How to Install
HACS Installation
Go to HACS → Integrations
Search for “Afvalbeheer”
Install the integration
Restart Home Assistant
Go to Settings → Devices & Services → Add Integration
Search for “Afvalbeheer” and follow the setup wizard
Manual Installation
Download the files from the repository
Copy to config/custom_components/afvalbeheer/
Add through the UI as above
Migration from Previous Versions
If you’re upgrading from v5.x:
YAML configurations will be automatically imported on first startup
Existing entities will continue to work without interruption
New UI configuration is available for future changes
No breaking changes to entity names or functionality
Recommended: Remove YAML configuration from configuration.yaml after successful migration
Testing Notes
As this is a new major version, please:
Test thoroughly before using in production
Report any issues on the GitHub repository
Backup your configuration before upgrading
Check entity names haven’t changed unexpectedly
Looking for Testers!
I need your help to make v6.0.0 rock solid!
Are you willing to help test this release? Your real-world testing with different waste collectors and configurations is invaluable for identifying any remaining issues.
Safe Testing - Easy Rollback
Don’t worry about getting stuck! You can always revert back to the previous stable version:
HACS users: Simply reinstall the previous version through HACS
Manual users: Replace files with the previous release from GitHub
Your YAML config: Will continue to work if you need to rollback
Entity history: Will be preserved during version changes
What I’m Looking For
Different waste collectors: Especially less common ones
Various configurations: Different address formats, special requirements
Edge cases: Commercial addresses, special suffixes, multi-instance setups
UI feedback: How intuitive is the new Config Flow?
Feedback Welcome
Please test and report:
Successful configurations with your waste collector
Any bugs or unexpected behavior
Suggestions for UI improvements
Documentation updates needed
Migration experiences from YAML to Config Flow
Let me know in the comments how v6.0.0 works for you and if you encounter any issues!
I think my upgrade to version 6 went without issues.
The only thing I noticed is that when I press “verzenden” (submit) on the following page in the config flow, nothing happens (not sure if this screen is supposed to close).
