0.12.0
Per-device internet control is coming to AsusRouter (using the parental control feature of routers)!
Including a binary_sensor
/ switch
for the global parental control (on
/ off
) with a full list of rules via the list
attribute.
Plus new service asusrouter.device_internet_access
to create a block
rule, disable
or remove
it.
Here is a small example of how to use it:
Button for a device internet control
Change {connected_device}
, {device}
and the mac value for the ones you need.
switch:
switches:
internet_{connected_device}:
friendly_name: Internet/{Connected Device}
unique_id: internet_{connected_device}
value_template: >
{% set ns = namespace(
mac = "01:23:45:67:89:ab"|upper,
list = state_attr("switch.{device}_parental_control", "list"),
internet = true
{# Find whether #}
{% for element in ns.list %}
{% if element.mac == ns.mac and element.state == "block" %}
{% set ns.internet = false %}
{% endfor %}
{{ ns.internet }}
turn_on:
service: asusrouter.device_internet_access
entity_id: device_tracker.{connected_device}
state: disable
turn_off:
state: block
Alternative - you can set the service state to remove
instead of disable
- this way rule will be removed from the list, not just disabled. Might be useful in case you are on the limit of the number of rules (32 / 64 depending on the router model).
Other changes
- Device-related events are getting
connection_type
andguest
attributes. - The same attributes are added to the device list of
connected_devices
sensor. - The new documentation is added to the integration.
- We are finally changing the last place not to use the correct
AsusRouter
naming - in the integrations list (it was still ASUS Router there). - Deprecated
asusrouter.service_reboot
is now removed.
The new version is available in HACS in 3โฆ 2โฆ 1โฆ Now
Want to support the development? Help me with getting an additional device for all the needed tests or Buy Me a Coffee
