I have it translated into the Slovak language, where do I send the json file?
You probably can add the file directly to the repository folder: https://github.com/Vaskivskyi/ha-asusrouter/tree/main/custom_components/asusrouter/translations
You will find a button “Add file” in the top-right of the box with the other files.
thx
add file is not possible but create new and then paste code is possible
Wohooo!!
Above is how to proceed.
That is super cool!
Indeed we will! I have 3 of those mesh devices.
@raspberrypi353 that’s very beautiful! Would you mind to share it (but i’ll totally understand if you won’t… it’s quite a job done here…)?
type: vertical-stack
cards:
- type: picture
image: local/images/ass.png
hold_action:
action: none
style: |
ha-card {
margin: 0rem 0.5rem;
-webkit-box-shadow: 0px 3px 6px 3px rgba(0,0,0,0.48);
-moz-box-shadow: 0px 3px 6px 3px rgba(0,0,0,0.48);
- type: custom:config-template-card
entities:
- sensor.myip
card:
type: custom:hui-entities-card
show_header_toggle: 'off'
style: |
ha-card {
entities:
- type: section
label: ${ 'Asus RT-AC86U' }
styles:
label:
- font-size: 10px
- type: custom:hui-vertical-stack-card
cards:
- type: horizontal-stack
cards:
- type: picture
style: |
ha-card {
image: /local/images/asrt.png
- type: custom:button-card
show_icon: true
show_state: false
style: |
ha-card {
entity: switch.rt_ax82u_wireless_2_4_ghz
show_icon: true
show_state: false
style: |
ha-card {
entity: switch.rt_ax82u_wireless_5_ghz
- type: custom:stack-in-card
style: |
ha-card {
cards:
- type: custom:mini-graph-card
color_thresholds:
- color: '#159F3B'
value: 0
- color: '#F2B528'
value: 50
- color: '#DD5129'
value: 80
decimals: 2
entities:
- entity: sensor.rt_ax82u_cpu
show_state: true
state_adaptive_color: true
font_size: 75
hour24: true
hours_to_show: 1
line_width: 3
points_per_hour: 120
update_interval: 10
- type: entities
entities:
- entity: update.rt_ax82u_firmware_update
- entity: button.rt_ax82u_reboot
- entity: light.rt_ax82u_led
state_color: true
- entity: sensor.rt_ax82u_ram
- entity: sensor.rt_ax82u_connected_devices
- entity: sensor.rt_ax82u_boot_time
- entity: sensor.rt_ax82u_wan_speed
- entity: sensor.rt_ax82u_lan_speed
decimals: 2
entities:
- entity: sensor.rt_ax82u_wired_download_speed
show_state: true
- entity: sensor.rt_ax82u_wired_upload_speed
show_state: true
font_size: 75
hour24: true
hours_to_show: 3
line_width: 3
points_per_hour: 30
update_interval: 300
entities:
- sensor.myip
card:
style: |
ha-card {
entities:
- type: section
styles:
label:
- font-size: 10px
cards:
cards:
- type: picture
style: |
ha-card {
image: /local/images/asus3.png
show_icon: true
show_state: false
style: |
ha-card {
entity: switch.asus_rt_ac86u_wireless_2_4_ghz
show_icon: true
show_state: false
style: |
ha-card {
entity: switch.asus_rt_ac86u_wireless_5_ghz
Hi and many thanks to Yevhenii for this project!!
I’m experiencing an issue in my HA asusrouter integration logging a lot of the same error:
Logger: asusrouter.util.parsers
Source: custom_components/asusrouter/bridge.py:230
Integration: AsusRouter (documentation, issues)
First occurred: 09:00:07 (189 occurrences)
Last logged: 09:31:07
Failed parsing value ‘isGN’. Please report this issue. Exception summary: (“Wrong value 3 of type <class ‘str’>”, None)
Failed parsing value ‘isGN’. Please report this issue. Exception summary: (“Wrong value 2 of type <class ‘str’>”, None)
My running configuration is:
- Asus Router model RT-AX88U - (acting as wireless router) Merlin FW 388.1
- HA Integration Vaskivskyi/ha-asusrouter 0.14.2
- Home Assistant 2022.12.5 - Supervisor 2022.11.2 - Operating System 9.4 - Frontend 20221213.0 - latest
Does anybody is experiencing the same issue and can help me to solve it?
Many thanks in advance
Regards
Hey @Gio70,
Thanks for your report!
Unfortunately, I will be able to check anything only after Saturday, since I currently do not have access to the testing environment. But since I have exactly the same RT-AX88U, the problem should not be hard to find and solve.
It seems like the backend library is receiving unexpected values. Can you let me know, which Guest WLAN networks you are using? 2.4 GHz or 5 GHz and the number of the network(s) in use - 1, 2 or 3?
0.14.3
Thanks to @EdwardTFN and @blavak68 AsusRouter now fully support
Portuguese (Brazil) and
Slovak correspondingly.
The full list of languages:
Czech -
English -
French -
Portuguese (Brazil) -
Slovak -
Spanish -
Ukrainian
You can always help us support even more languages!
Links:
Hi Yevhenii, thanks for your reply, but take some time to solve it I’m not in a hurry, indeed thanks to you for spending your time to produce this component. Here what you need (I think). Guest 1 not used.
Do not hesitate if you need more information
Regards
Giorgio
The fix will be available with the next release. Sorry for this bug
0.15.0
More temperatures and fixes
2022-12-18
Known issues
- Updating to this version might disable your current temperature sensors and create new ones. In this case, please remove the old entities, enable the new ones and assign them entity_id’s as before.
Requirements
- Minimum Home Assistant version bumped to
2022.11.0
New features
- New
guest_idinteger attribute added to the device identities (anddevice_trackerentities), which shows the number of guest WLAN (e.g.1,2or3when connected or0when not connected to a guest network) - Added support for the temperature of
5 GHz-2and6 GHzwireless modules (device and firmware dependant)
Bug fixes
Breaking
- Deprecated in 0.13.0
entity_id,macandnameparameters ofasusrouter.device_internet_accessservice are removed - Migration from versions 0.5.1 and lower is removed - consider the new migration FAQ if you need to update from an older version
Documentation
Documentation webpage
- Search feature is added to the documentation using the Algolia DocSearch platform
- Change log is added to the documentation
- Credits are added to the documentation
Dependencies
- Bump
asusrouterlibrary to0.14.0
Github / HACS
- Update build status badge
- Update release drafter
Other changes
integration_typeproperty is added to the manifest (>= 2022.11.0) - Switched to
UnitOfTemperatureenum (>= 2022.11.0) - Switched to
SourceTypeenum (>= 2022.9.0) - Code improvements
Support AsusRouter development
If you like AsusRouter, you can consider supporting its development by donating using the Buy Me a Coffee service.
Achievements
- AsusRouter integration has crossed 600 active installations (as per HA Analytics) - currently, 607 installations are reported.
- AsusRouter documentation is visited by more than 400 unique users per month (those, not blocking Google Analytics).
Announcements
Hi Yevhenii, applied update and now works fine! Bought a coffee for you!
Thanks & Regards
G.Casale
Hey,
I did a push request for Dutch translation. Did you got it?
Hey, sorry I did not get anything. Did you create a Pull Request after pushing changes to your fork?
