if you have components/platforms that are affected, then yes
could this be made to work in a HA 84.3 setup also?
Iv tried to rename the component and file it under /custom_components/sensor/breaking_changes.py and of course use
- platform: breaking_changes
also change the line in const.py:
REQUIRED_FILES = ["const.py", "breaking_changes.py"]
like is still the way to do it in 84.3. Placed the const.py file in the same folder.
Unfortunately I get a config error, invalid config…
before I try further, please would you let me know if this would at all possible?
thanks
I have no idea and will not try to keep compability for other than the latest version of HA.
0.84 is a long time ago, and that was before “The great migration”, it should be doable, but I do not know how much you need to change.
You should really look into upgrading your system.
haha, you’re funny, of course that’s exactly what I am trying to do, and see which breaking_changes I face…
This doesn’t really help a lot when trying a component which is supposed to be designed to see which are the breaking changes between versions of HA…
but I can appreciate that in the rate HA is developing, such a component would be a day-job… so no worries, Il try to get the most out of the website, and start here https://hachanges.halfdecent.io/84
thanks for that!
Good luck!
I’m relatively new to HA and got this installed. What’s the best way to show this in a Lovelace card? Someone must’ve tackled this already?
I have a card for update monitoring where I use a conditional card and custom:list-card for a table view of the sensor attributes.
type: custom:vertical-stack-in-card
cards:
- type: markdown
content: "## Update Status"
- type: entities
show_header_toggle: false
entities:
- entity: sensor.hacs
- entity: sensor.potential_breaking_changes
- type: conditional
conditions:
state_not: "0"
card:
type: custom:list-card
columns:
- title: Component
add_link: doclink
field: component
- title: Description
add_link: prlink
field: description
@JBunch perfect thank you! Exactly what I needed, i just used your card config as-is to add it to an ‘Advanced’ tab in my lovelace dashboard.
Awesome
Hi, sorry here is a newbe question for you. I used HACS to install Breaking Changes module. No problems. Then I rather gussed … that I should add the “breaking changes:” in the configuration.yaml file (it was semi clear from the instructions (my view).
But now, where do I see the outcome? This is not clear for me, but I have a lot more to learn about HA, but i love it.
3 posts above yours, post by @JBunch
@nickrout, so just to be sure, there is no other way to see this, like in a log file or info or similar, I need to create a card, do the scripting (or copy from above) and read it that way? In such case, as I said, lot to learn!
Thx!
I am guessing this integration no longer works as the site it relies upon has been down for a very long time?
https://hachanges.halfdecent.io/ works perfectly fine for me?
yep, always check it first.
with my sunglasses, the horrific color must be a practical joke
was using the default material colors, that has changed now ![]()
Was not expecting anyone to use the actual site
Is anyone else able to ge this to work, on my installation the list card does not display the data, its just blank:
Do you have feed_attribute: changes before the columns: options in the list-card config?
That did it, thank you! I love these forums, so many great folks here. Here is my revised code to help others:
cards:
- content: '## Update Status'
type: markdown
- entities:
- entity: sensor.current_ha_version
type: entities
- card:
columns:
- add_link: doclink
field: integration
title: Component
- add_link: prlink
field: description
title: Description
type: 'custom:list-card'
conditions:
state_not: '0'
type: conditional
type: vertical-stack
What it looks like:
Nice but i cant find the list-card anymore in HACS
