Have this now:
default: warning
logs:
custom_components.esxi_stats: error
But the error persists
Have this now:
default: warning
logs:
I used this to stop the warning messges:
logger:
default: warning
logs:
homeassistant.util.async_: critical
i am not sure if i am just too stupid…
After intalling the repository in HACS and restarting, ESXi Stats is not listed in my integration list…
Did i miss something?
Press F5 while in the integrations menu, then press the +
Hi. I did some testing, and I can not get it to work with vCenter 7. I believe they made changes to how the API works, but I am not sure. I would really appreciate it if you could fix this.
Thanks,
Christian
Hi wrt9861 and team,
I’ve setup the sensors and used your button card template in a grid card. I cannot for the life of me figure out how to shift the main sensor info more to the left so the full figures can be seen. Hopefully the screenshot helps show what i mean here…
Any ideas?
Thanks!
I am trying to use the esxi_stats.vm_power to shut down a VM.
I just receive the error “Make sure the name is correct”
Am I missing something obvious ? Thank You. Chris
2021-01-20 15:12:13 DEBUG (MainThread) [custom_components.esxi_stats] Getting stats for vm: nakivobackup
2021-01-20 15:12:13 DEBUG (MainThread) [custom_components.esxi_stats.esxi] {'name': 'nakivobackup', 'status': 'green', 'state': 'running', 'uptime_hours': 94.7, 'cpu_count': 2, 'cpu_use_pct': 0.7, 'memory_allocated_mb': 4096, 'memory_used_mb': 1780, 'used_space_gb': 8.33, 'tools_status': 'toolsOk', 'guest_os': 'Ubuntu Linux (64-bit)', 'guest_ip': '192.168.1.245', 'snapshots': 0}
2021-01-20 15:12:13 DEBUG (MainThread) [custom_components.esxi_stats.esxi] Logged out - session 52f4a939-8603-b640-85e9-265ce8de5198
2021-01-20 15:12:37 DEBUG (MainThread) [custom_components.esxi_stats.esxi] Logged in - session 52a54b0a-91bf-5efc-8c1a-aac9c1bdbbcd
2021-01-20 15:12:37 INFO (MainThread) [custom_components.esxi_stats.esxi] VM nakivobackup on host 192.168.1.242 not found. Make sure the name is correct
2021-01-20 15:12:37 DEBUG (MainThread) [custom_components.esxi_stats.esxi] Logged out - session 52a54b0a-91bf-5efc-8c1a-aac9c1bdbbcd
Nice integration but…
Found also the error with the " - "
if you have for instance 2 vm’s running. vm1: hass.io and vm2 hass.io-2.
If you use the ‘esxi_stats.remove_snapshot’ to remove the snapshot for hass.io-2 it will actually remove the snapshot from hass.io. it seems the integration cannot handle the “-” !
and it would be nice if the error log spamming could be solved.
Nice integration, i love it !!
but can esxi server be shut down from this integration?
I would like that when my ups is at 10% load, it does a shutdown of the esxi server.
is it possible?
nice day
Is ESXi Stats work for you after upgrade to 2021.4? For me integration seems to load, but none of entities are available.
For me it works, there were some updates for esxi, but not relevant for 2021.4, they were for the loop fix
Make sure to update to the latest version, should be 0.6.1
Yeap, I completely removed integration (previously had it installed manually) and re-added from HACS. Now everything back to normal!
Hi @deliwyn I"m really not sure where to place that in here for the middle tile showing datastore capacity. Any clues please?
esxi_stats_datastores:
icon: 'mdi:harddisk'
aspect_ratio: 1/1
template: esxi_stats_general
styles:
grid:
- grid-template-areas: '"i free" "n n" "capacity capacity" "hosts hosts" "vms vms"'
custom_fields:
capacity:
- font-size: 12px
- padding-bottom: 2px
- align-self: middle
- justify-self: start
hosts:
- font-size: 12px
vms:
- font-size: 12px
Thanks for this integration; great work.
Just wondering how to get temperature sensor and fan speed readings. These are available in vCenter/host/monitor/hardware, can they be accessed via this integration?
Cheers
Hi, Would you mind sharing the code for this card?
Sure thing:
template: vm_entity_template
type: custom:decluttering-card
variables:
- entity: sensor.esxi_vm_pxe_boot_2
- name: PXE Boot
Here’s the decluttering template:
decluttering_templates:
vm_entity_template:
card:
entities:
- entities:
- attribute: state
- attribute: uptime_hours
unit: hr(s)
- attribute: snapshots
entity: '[[entity]]'
icon: mdi:server
secondary_info:
attribute: guest_os
show_state: false
type: custom:multiple-entity-row
- entities:
- attribute: cpu_use_pct
unit: '%'
- attribute: memory_used_mb
unit: MB
- attribute: cpu_count
icon: mdi:speedometer
name: '[[name]] Performance'
show_state: false
- entities:
decimal: '0'
height: 15px
max: '100'
min: '0'
severity:
- color: var(--label-badge-green)
to: '40'
- color: orange
to: '65'
- color: var(--label-badge-red)
to: '100'
unit_of_measurement: '%'
entity_row: true
positions:
icon: 'off'
indicator: inside
style: |-
bar-card-name {
font-weight: bold;
text-shadow: 2px 2px 2px black;
bar-card-value {
font-weight: bold;
animation:
state: 'on'
type: custom:bar-card
- attribute: guest_ip
icon: mdi:ip
type: attribute
- attribute: used_space_gb
icon: mdi:harddisk
suffix: GB
type: attribute
title: '[[name]]'
type: entities
Hi @wxt9861 and team. Since a few weeks now I seem to be missing all attributes except the default one. See below my version of default datastore entity.
Mine:
Expected as per that found here https://github.com/wxt9861/esxi_stats
Can anyone shed any light on why this might be? This issue is causing my custom cards to go all loopy:
Thanks for your help!
just a small message to say thanks - im using this integration now with my vcenter environment. works really well … ive setup multiple automations to shutdown vms or start them only when needed (security scanning / backup servers) . Ive built based on the APC UPS monitoring card also a card for monitoring my ESX servers:
If anyone is interested in the YAML let me know.
on my wishlist: could we include host power control as well - eg extending more of the vmware api ? my goal is to standby hosts which are not needed for saving power but spinning up as i start my day.
