Any chance we can change the values it reports for memory for each VM? Right now, it shows memory allocated and memory used. Neither value is really that important. What would really be useful is the current active memory.
Yes. Submit an issue request via github please.
You can find configuration steps in documentation. https://github.com/wxt9861/esxi_stats#configuration-options
yeah I know that page.
Ok apparently there was something wrong and I didnāt found the ESXi stats in the integration page but now I do.
Hi there,
is it possible to get all vm ipās and not only the one on the primary nic?
greetings
hi all - no bug or question ā¦ just wanted to give an headsup i tested this component with vCenter 8.0 and so far it works ā¦ i get sensor information in HAā¦didnt test the power controls yet ā¦but i assume APIās stay the same so functionality should workā¦
Great job with these components.
Just a question (Iām new to home assistant, Iām really a beginner) and I would like to know if itās possible to have āused_space_gbā for datastores?
I want to create a graph with the remaining space on the datastore but for that I need to have the information of the space already used. Or is there another way to do it?
Thank you for your help !
Yes, integration provides sensor sensor.esxi_datastore_xxx (where xxx is the name of datastore from ESXi host) that gives a lot of information about datastore usage via attributes). Here is example from my config:
Thank you for this answer.
But there is no āused_space_gbā attribute for datastores.
Is there any way to get it OR to get it using a formula (total - free = used) and if so, where and how can I do it?
Thanks !
Yes, you need to create template sensor for this. Here is the sample of sensor I created for my datastore (and sensors I use to provide some usage data directly as state, instead of attirbutes and with additional convertion to GB):
sensors:
esx_datastore_used_space_gb_1:
friendly_name: "ESXi Host LocalDatastore Used"
value_template: >-
{{ states['sensor.esxi_datastore_local'].attributes.total_space_gb - states['sensor.esxi_datastore_local'].attributes.free_space_gb }}
icon_template: mdi:harddisk
esx_datastore_total_space_gb_1:
friendly_name: "ESXi Host Local Datastore Total"
value_template: >-
{{ states['sensor.esxi_datastore_local'].attributes.total_space_gb }}
esx_datastore_used_space_1:
friendly_name: "ESXi Host Local Datastore % Used"
value_template: >-
{{ (states('sensor.esx_datastore_used_space_gb_1') |float(default=0) / states('sensor.esx_datastore_total_space_gb_1') | float(default=0) * 100) | round(0) }}
Ok nice ! thank you!
Can I ask you a huge favor.
If I give you the following information, can you write me the template that would allow me to get āused_space_gbā.
I will use this first template as a learning base to understand how it works.
This would be:
sensors:
value_template: >-
{{ states['sensor.esxi_datastore_datastorewv'].attributes.total_space_gb - states['sensor.esxi_datastore_datastorewv'].attributes.free_space_gb }}
Ok je comprends, un tout grand merci pour ton aide !
I think this is what state_attr
is for no?
sensors:
value_template: >-
{{ state_attr('sensor.esxi_datastore_datastorewv','total_space_gb') - state_attr('sensor.esxi_datastore_datastorewv','free_space_gb') }}
Yes, just different notationā¦ I created that sensors looong time ago
Hi
First, thanks for this excelent Component it really makes sense with APC USB SAI with NUT Server and NUT Client to do this automation:
Now the question:
Is it possible to shutdown the ESXI HOST with or without delay? It would be beatiful to turn off the vmās and then the host.
thanks!!
Iām still newb with HA, its possible to install 0.7beta with HACS?
Go to HACS and click on integration tile. From upper right corner 3-dots icon choos Redownload and activate Show beta versions:
done, thanks a lot!!
