Custom component for iZone air conditioner
Thanks for your contribution to HA.
I know you have limited time, but I hope you can guide me on the right track.
I was using iZone in VM Qnap and it worked, but that Qnap is no more.
I am now running OS on a NUC (no VM). When trying to add integration, it fails and I get the error codes below regarding discovery. I have disabled duckdns and running local on http. Is there anything I can do to see if I can make this work?
Many thanks for your time.
Logger: pizone.discovery
Source: /usr/local/lib/python3.11/site-packages/pizone/discovery.py:173
First occurred: 14:47:30 (2 occurrences)
Last logged: 14:57:02
Uncaught exception
File “/usr/local/lib/python3.11/site-packages/pizone/discovery.py”, line 408, in initialize_controller
await controller._initialize() # noqa: E501
File “/usr/local/lib/python3.11/site-packages/pizone/controller.py”, line 113, in _initialize
await self._refresh_zones(notify=False)
File “/usr/local/lib/python3.11/site-packages/pizone/controller.py”, line 395, in _refresh_zones
await asyncio.gather(
File “/usr/local/lib/python3.11/site-packages/pizone/controller.py”, line 400, in _refresh_zone_group
assert group in [0, 4, 8]
AssertionError
This has all been working great again for a good while now, still no luck with the power sensor unfortunately.
Another feature request though, is there any chance of reading in the sleep timer from iZone into Home Assistant as an additional sensor or state? Ideally two way but one way would be fine too. The iZone app itself is still not great, home assistant does everything better than their own app, but I use HA for a sleep timer automation, Wife still likes to use the iZone sleep timer. No big conflicts or anything, just would be nice to be able to update one based on the other being altered.
Why not just implement the sleep timer in HA instead?
Just reinforcing what I’ve said above:
If someone wants to work with me to get PRs accepted in HA, then we can get some changes made to the HA integration and make some forward progress with adding features and correcting bugs. It would need to be someone familiar with coding so they can do code reviews.
What might be a better option would be that the whole integration is pulled out of HA and put into HACS instead, because then I don’t have to worry about code reviews and can just publish. The downside of this is that as the codebase of HA shifts, the HA people will automatically fix any inconsistencies which reduces the amount of work needed. Without this there’s a chance the integration would no longer work in HA with one of the updates.
At the moment the component works OK for me, so my motivation to do this kind of stuff is pretty low and I have a stack of higher priorities to contend with.
I do that, but if the timer is activated in the iZone app or panel instead, it isnt acessible or readable by HA, so I have no way to keep the two in synch. First world problems, no biggie. The power monitoring would be a much bigger benefit. in my case at least.
If I had some idea of how to go about doing that, I’d be more than happy to help, feel free to point me in the right direction and I’ll try to do what learning I need to do to be useful/helpful. Id be heavily relying on AI nowadays tbh but I have a bit more time on my hands than I used to, im willing just need to learn what i need to learn to help out.
Are you a python coder, or some kind of coder? Contact me on the discord is probs a good way forward, name is Penny, user id is swamp_ig
I’m a hobby level nerd. Learning python, but only slowly and only on an as-needed basis, im not about to be proficient anytime soon. But I can muddle my way through sometimes with youtube and google and ai holding my hand.
Hi Penny, thanks for your work on the integration.
If you don’t have iZone sensors in a zone, is it possible to map a temp sensor entity to the current_temperature attribute and then would this enable the climate target temperature features for that zone?
The temperature management features are within the iZone controller, HA just interfaces with that.
You can go into the config settings for the unit and associate sensors with zones through, as long as there’s a flutter valve it will work.
Thanks for the response.
Do you know if iZone sensors with pushbuttons expose to HA? I.e. does each button expose as a button entity in HA, likewise motion sensor?
I haven’t coded this, no.
It would likely be possible to query iZone for the state of the controlled relays, but probably not the button-press events themselves. The integration works with regular polling of the system, the device doesn’t send out status notifications.
NB: This integration is not actively being maintained, see above.
Hey Penny, I’m a software dev and have recently inherited a super cool izone system. I would happily contribute to the project to build out the smart lighting integration. I haven’t really looked through the documentation in detail.
If you’re interested in my collaboration, what would be the best way to get in contact?
