Custom Component for Waveshare ESP32-S3 4.2" RLCD (ST7305)
I also get the pop sound. I have not investigated further. Here is how I am setting the default volume. 75% is fine for me with the speaker taped to the back of the unit, above that there is too much distortion IMO.
  on_boot:
    priority: 800
    then:
      # turn on PA before initializing es8311
      - switch.turn_on: audio_pa_ctrl
      - delay: 100ms
      - speaker.volume_set:
          volume: 75%
I think I fixed the pop sound
  on_boot:
    priority: 800
    then:
      - delay: 300ms   # increase this
          volume: 0%
when playing sound
    volume: 75%
Have you tried displaying a image?
I tried
http_request:
online_image:
  - url: http://homeassistant.local:8123/local/snapshots/frontdoor.jpg
    format: JPEG
    update_interval: never
    type: BINARY
then
it.image(0, 0, id(door_snapshot));
but nothing shows
hey,
i’ve tried several configs, but my screen it only showing some snow on my device and in 2 parts (but not equally). On the left side mostly white, on the right mostly black. any ideas?
refresh changing to 1s doesn’t change
esphome:
  friendly_name: RLCD
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
# CRITICAL: Enables the 8MB Octal PSRAM required for the display buffer
psram:
  mode: octal
  speed: 40MHz
logger:
api:
  encryption:
    key: ""
ota:
  - platform: esphome
    password: ""
# ===== Wi‑Fi =====
wifi:
  ssid: ""
  password: ""
  # Fallback AP; handig bij Wi‑Fi issues
  ap:
    ssid: "Esp32S3 Fallback Hotspot"
    password: "CxWcHMh6SjcC"
# Captive portal voor fallback-AP
captive_portal:
spi:
  clk_pin: GPIO11
  mosi_pin: GPIO12
  #miso_pin: GPIO8      # Added dummy pin to satisfy SPI initialization
# External component
external_components:
  - source: github://kylehase/ESPHome-ST7305-RLCD
    components: [ st7305_rlcd ]
    refresh: 0s
font:
  - file: "gfonts://Roboto"
display:
  - platform: st7305_rlcd
    model: WAVESHARE_400X300
    rotation: 0
    width: 400
    height: 300
    cs_pin: GPIO40
    dc_pin: GPIO5
    #te_pin: GPIO6
    reset_pin: GPIO41
    data_rate: 1MHz
    show_test_card: false
    lambda: |-
      // Get dimensions
      int w = it.get_width();
      int h = it.get_height();
      id(my_display).display_on();
      // Print "Hello World!" in the center of the screen
      // Arguments: x, y, font_id, color, alignment, text
      it.printf(w / 2, h / 2, id(roboto), COLOR_ON, TextAlign::CENTER, "Hello World!");
      id(my_display).low_power_mode();
you may want to draw a full rectangle on the display after initialisation (with a delay of 100ms or so) to ensure the buffer is fully initialized. I get random pixels/noise on boot-up too until the display is redrawn.
I was able to display an image that I included locally. I did use a PNG though.
Code (abridged):
image:
  - file: "images/image480.png"
    type: BINARY
    resize: 198x198
and in the display lambda (some placement tricks to make it fit into an unused test area):
     // Right-hand image area (200x220 box from x=200..399, y=40..260)
      const int img_w = 198;
      const int img_h = 198;
      // Center the 200x200 image in that box
      const int right_x = left_w + ((w - left_w - img_w) / 2) +1;          // 201, leave center bar alone
      const int right_y = content_top + ((content_bottom - content_top - img_h) / 2);  // 50
      it.image(right_x, right_y, id(rlcd_photo), COLOR_OFF, COLOR_ON);
Hi
You probably need to ajust the refresh and the update intervals
See Custom Component for Waveshare ESP32-S3 4.2" RLCD (ST7305) - #15 by eponra
Hi
This is my config which uses some HA sensors
Thanks to kylehase and oliof for their incredible work!
esphome:
  friendly_name: RLCD
globals:
  - id: is_inverted
    type: bool
    initial_value: 'false'
esp32:
  framework:
    type: esp-idf
psram:
  mode: octal
  speed: 40MHz
logger:
api:
  encryption:
    key: "xxxxxxxxxxxx"
ota:
  - platform: esphome
    password: "xxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Display Fallback Hotspot"
    password: "BG9KYOJOWLlQ"
captive_portal:
spi:
  clk_pin: GPIO11
  mosi_pin: GPIO12
i2c:
  sda: GPIO13
  scl: GPIO14
  scan: true
    refresh: 6s # Cache the component unless you are actively developing it
font:
  - platform: adc
    pin: GPIO4   # This is the correct pin for RLCD-4.2
    attenuation: 12db
    update_interval: 60s
    filters:
      # The divider is 100k+100k (1/2) or 200k+100k (1/3)
      # Start with 2.0. If it reads ~2.1V for a full battery, change to 3.0.
      - multiply: 3.0
      # Smooth out the jitter
      - sliding_window_moving_average:
          window_size: 10
          send_every: 1
      # Optional: Convert voltage to percentage
  - platform: copy
    source_id: bat_voltage
    unit_of_measurement: "%"
    filters:
      - calibrate_linear:
          - 2.5 -> 0.0
          - 4.2 -> 100.0
      - clamp:
          min_value: 0
          max_value: 100
  - platform: shtcx
    temperature:
      name: "Ambient Temperature"
    humidity:
      name: "Ambient Humidity"
    address: 0x70  # Standard SHTC3 address
    i2c_id: bus_a
text_sensor:
  # Text Sensors (Detected from Sensor Text)
  - platform: homeassistant
    entity_id: sensor.rte_tempo_couleur_actuelle
    #internal: true
    entity_id: sensor.rte_tempo_prochaine_couleur
    #internal: true
    entity_id: sensor.lixee_current_price
    #internal: true
time:
display:
    rotation: 0
    width: 400
    height: 300
    cs_pin: GPIO40
    dc_pin: GPIO5
    #te_pin: GPIO6
    reset_pin: GPIO41
    data_rate: 1MHz
    update_interval: 5s
    lambda: |-
      // 1. Determine Colors based on the global toggle
      auto bg = id(is_inverted) ? COLOR_ON : COLOR_OFF;  // Swap Background
      auto fg = id(is_inverted) ? COLOR_OFF : COLOR_ON;  // Swap Text Color
      // 2. Wake up
      it.filled_rectangle(0, 0, w, h, bg); // Clear previous screen
      // 2. Draw "Hello World"
      it.printf(w / 2, h / 2, id(roboto), fg, TextAlign::CENTER, "A %s  | D %s", id(couleur_actuelle_txt).state.c_str(), id(prochaine_couleur_txt).state.c_str());
      it.printf(w / 2, h / 3, id(roboto), fg, TextAlign::CENTER, "%s", id(ltarf_txt).state.c_str());
      it.strftime(w / 2, h * 2 / 3, id(roboto), TextAlign::CENTER, "%H:%M:", id(ha_time).now());
      // 3. Sensors (Temp, Humidity, Battery Level)
      if (id(rlcd_temp).has_state() && id(rlcd_hum).has_state()) {
        it.printf(w / 2, 30, id(roboto), fg, TextAlign::CENTER,
                  "T %.1f°C  |  H %.1f%% | B %.0f%%", id(rlcd_temp).state, id(rlcd_hum).state, id(bat_level).state);
      } else {
         it.printf(w / 2, 30, id(roboto), fg, TextAlign::CENTER, "Loading Sensors...");
      // 4. Power Save
### buttons
# left: User Button
#   Bug: GPIO18
# center: Power Button.
#   Long press to turn off, short press to turn on.
#   Bug: When turned on while on battery, display not initialized correctly
# right: Boot Button (GPIO0)
binary_sensor:
  # 1. The "BOOT" Button (Top side button)
  - platform: gpio
    pin:
      number: GPIO0
      inverted: true
      mode: INPUT
    # Example Action: Force a screen refresh when clicked
    on_press:
      - component.update: my_display
  - platform: gpio
    name: "Button Key (GPIO18)"
    pin:
      number: GPIO18
      inverted: true
      mode: INPUT # Try PULLUP. If fails, remove this line (some boards have HW pullup)
    on_press:
      - logger.log: "KEY BUTTON PRESSED"
      # 1. Toggle the variable (true -> false -> true)
      - globals.set:
          value: !lambda 'return !id(is_inverted);'
      # 2. Force the display to redraw immediately with new colors
This screen is a great alternative to e-paper, I had a waveshare e-paper display before which I used as a clock, partial refreshing every second, I know I wasn’t suppose to do that, hence it died after 2 years.
With this LCD screen I’ve programmed it as a Clock/Weather Station, taking sensor data from HA, showing weather forecast, hourly and daily. Plus temp/humidity from sensor around the house.
Also when I’m doing 3D print, instead of showing weather data, it shows the progress of the 3D print, when print is complete, it plays a chime to let me know it’s done. When I turn the printer off, it reverts back to weather.
Very happy with this screen/hardware.
Unfortunately what the screen can’t do is maintain the display in deep sleep. I am trying to explicitly manage power for the audio and wifi components, but I haven’t been too successful yet.
Thanks for the great work here.
Is there a way to configure waveshare rlcd 4.2 display in ESPHome Designer to simplify writing lambdas or LVGL?
Thank you in advance
Hi, just got two of these displays and fiddling around with them.
First, the driver works great. :slight_smile:
But sadly, I cannot get LVGL working. Maybe it isn’t really neccessary to use this but self aligning layout managers sound cool to me.
All I get is a black screen:
# Board: ESP32-S3 DevKitC-1 (Espressif)
# Definition: definitions/boards/esp32-s3-devkitc-1/manifest.yaml
esphome:
  friendly_name: "RLCD-Monitor"
# these are hardware definitions
esp32:
  framework:
    type: esp-idf
psram:
  mode: octal
  speed: 80MHz
spi:
  clk_pin: GPIO11
  mosi_pin: GPIO12
i2c:
  sda: GPIO13
  scl: GPIO14
  scan: true
    components: [st7305_rlcd]
font:
  file:
    type: gfonts
    family: Roboto
display:
    width: 400
    height: 300
    cs_pin: GPIO40
    dc_pin: GPIO5
    reset_pin: GPIO41
    auto_clear_enabled: false
# next is connection setup
api:
  encryption:
    key: ***********************************************************
ota:
  - platform: esphome
wifi:
  ap:
    ssid: RLCD-Monitor Fallback Hotspot
    password: ********************
# mandatory logger
logger:
# this defines the lvgl view
lvgl:
  update_when_display_idle: false
  bg_color: WHITE
  widgets:
    - label:
        text: "Hellorld"
        align: CENTER
        text_color: BLACK
        line_color: BLACK
        text_align: CENTER
can someone help?
