That is also the avenue I was looking into, although the documentation is written towards someone with a better handle on the framework of home assistant integration development.
I have upgraded everything today, including the HA Core and now I am having this:
I think I need to add googleapiclient to the manifest.json?
When I try to delete the GTasks integration it does nothing and shows this:
This error originated from a custom integration.
Logger: aiohttp.server
Source: custom_components/gtasks/gtasks_api.py:7
Integration: GTasks (documentation)
First occurred: 2:05:51 PM (1 occurrences)
Last logged: 2:05:51 PM
Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 82, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 84, in delete
result = await hass.config_entries.async_remove(entry_id)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 911, in async_remove
await entry.async_remove(self.hass)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 532, in async_remove
component = integration.get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 638, in get_component
cache[self.domain] = importlib.import_module(self.pkg_path)
File "/usr/local/lib/python3.10/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/config/custom_components/gtasks/__init__.py", line 17, in <module>
from .gtasks_api import GtasksAPI
File "/config/custom_components/gtasks/gtasks_api.py", line 7, in <module>
import googleapiclient._auth
ModuleNotFoundError: No module named 'googleapiclient'
