@pathia The feature I implemented for you is currently being blocked for integration into homeassistant core. If you or anyone else wants to get into the discussion here is the PR:
Iām sorry to hear that. Unfortunately I am not that deep into this project. I think you pointed out the actual use case perfectly. I think it isnāt much use if I come and repeat your story. I think we should wait for a second reviewer and wait for the outcome. Thank you so far
First I love this component, thank you. However I keep running into a terminal issue. When I first set it up, it tracks time from A to B without any issue, but after X time (hours). It stops updating time on the front end. On reboot of HASS I get the following error:
Invalid credentials. This error is returned if the specified token was invalid or no contract could be found for this token.
I tried everything but could not clear the error. I decided to delete the Here app, create a new one to get a new ID and Code. Same thing, worked for an hour or so then the same error came back. Any suggestions?
Running HASS 0.100.1
My config looks like this:
app_id: "MY_ID"
app_code: "MY_CODE"
name: Mhairi to Home
traffic_mode: true
origin_entity_id: device_tracker.life360_mhairi
destination_entity_id: zone.home
You can set the log level to debug and send me the log files via direct message. When debug is activated we can see the actual request and response payload and dig deeper from there.
To enable debug log level you can put the following into your configuration.yaml:
@eifinger tonight I upgraded my hass io from 0.99.2 to 0.100.2 and now I have this weird sentence in my logfile.
Iāve copy-pasted it one on one. Are they trying to say it is blacklisted ? Although they specify not blacklisted they to suggest to remove it.
2019-10-15 20:51:08 ERROR (MainThread) [hacs] You have eifinger/here_travel_time installed with HACS, this repositroy have not been blacklisted, please consider removing it.
Edit: I tried to remove the component (again using HACS) and now I canāt find it back in the HACS store. I think HACS was trying to tell me that the component was blacklisted?
Hi @pathia. Starting with version 0.100 the component officially integrated into home-assistant. Thatās why I blacklisted it in HACS.
I forgot to post an official message here.
Thank you for the clarification. I have manually restored the version from Github to custom_components and now it works like it did before. Letās see how the PR with the fix works out.
Thatās just fine. Iāll just stick with the āoldā version. Which I absolutely love. It is great to have a fast look at the current traffic. Thanks for the update!
Facing bothersome performance issues and unavailabilities with travel info of āDeutsche Bahnā I remember that you thought about providing route calculation with public transport. Is that idea still relevant?
I was wondering if anyone had created a sensor that used input_text as the origin/destination entity ID. I was thinking I could maybe have an input text where I could enter addresses.
