I already added it few months ago follow your suggestion, there should be a printer sensor represents that information
This is what I see, although the printer is in power save mode (inPowerSave). Is this what I expect to see?
Will send later the mapping
PRINTER_STATUS = {
"ready": "On",
"scanProcessing": "Scanning",
"copying": "Copying",
"processing": "Printing",
"cancelJob": "Cancelling Job",
"inPowerSave": "Idle",
"": "Off",
Managed to understand how it goes.
Also works with HP LaserJet Pro MFP M26nw.
Tiago
I installed and configured the component for my HP printer without problem. Thank you for the good work!
Is there any way to send commands to the printer, like printing a test page on a regular basis?
In configuration log I have warnings:
Value cannot be processed as a number: <state sensor.hp_4645_inkcartridge_cyanmagentayellow=0; unit_of_measurement=%, friendly_name=HP 4645 Inkcartridge CyanMagentaYellow, Color=CyanMagentaYellow, Type=Inkcartridge, Station=N/A, Product Number=N/A, Serial Number=N/A, Manufactured By=N/A, Manufactured At=N/A, Warranty Expiration Date=N/A, Installed At=N/A, icon=mdi:cup-water @ 2020-12-15T11:34:56.548417+02:00> (Offending entity: %)
Value cannot be processed as a number: <state sensor.hp_4645_inkcartridge_black=20; unit_of_measurement=%, friendly_name=HP 4645 Inkcartridge Black, Color=Black, Type=Inkcartridge, Station=N/A, Product Number=N/A, Serial Number=N/A, Manufactured By=N/A, Manufactured At=N/A, Warranty Expiration Date=N/A, Installed At=N/A, icon=mdi:cup-water @ 2020-12-15T11:34:56.551370+02:00> (Offending entity: %)
What can be done to correct them ?
hp deskjet 2655 supported by this ? i was able to install intergation through hacs but can’t find it under configuration > integrations
Did you get it up and running?
I have the same problem. I have had it earlier, but made a fresh HA installation and can’t get it working now.
yes i got it working yesterday, idk what happened but my integration was not showing under config - > integration
Has the component been removed from HA Integrations? Nothing appears, other than IPP or are we suppose to add it via HACS?
You should install it from HACS first
I only have these sensors showing up. Where are other sensor that show breakdown of the printing and scanning?
- sensor.hp_envy_5000_series_uptime
- binary_sensor.hp_printer_connectivity
- sensor.hp_printer_inkcartridge_black
- sensor.hp_printer_inkcartridge_cyanmagentayellow
- sensor.hp_printer_printer
- sensor.hp_printer_scanner
- sensor.hp_printer_status
Have a issue with the status of the printer. Everything look fine in the setup. I get the values of the cartridges and the status value showing “Idel”.
The problem is that if I print 1-2 pages, it never changes from Idel to Printing. If I print a lot of pages it does.
I think it must be something with the polling interval. Any way to change this the pollong interwal. I can not find it.
not showing in HACS either
Edit: found
I have tried installing this integration but its not appearing in list of Integrations, even though the log file mentions it as untested by Home Assistant. I’m sure I had it working on a previous version of HA. I’m now running 2021.12.6.
Anyone else have the same problem?
Could be relared to browser cache, pls try it adter clearing the cache
Sorry, I found the issue. The permissions were set incorrectly so the foldersd were not writeable. Changed that and it now works fine.
Found the integration but it won’t set up. I get this:
Translation Error: The intl string context variable "IP" was not provided to the string "Invalid server details, please try manually access to `http://{IP}//DevMgmt/ProductStatusDyn.xml` (Replace placeholder with IP or Hostname), in case it's accessible, please report the issue with logs"
Can you post the XML resulted from the request in the log message?
