I have the same issue as DevTNT
Did you ever find a solution?
Hello! I have an HappyLighting RGB Strip that gets recognized in bluetooth as QHM-F439.
The script didnât pull the address automatically so I had to get it manually.
I get an error named âUnknown error occuredâ.
The log says:
2022-09-18 15:39:39.788 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration candy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experienc>
2022-09-18 15:39:39.791 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration triones which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experie>
2022-09-18 15:39:39.792 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience>
2022-09-18 15:40:09.151 WARNING (MainThread) [homeassistant.helpers.frame] Detected integration that attempted to call BleakClient with an address instead of a BLEDevice. Please report issue to the custom integration author for triones >
2022-09-18 15:40:09.158 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 82, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 178, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 73, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 280, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/config/custom_components/triones/config_flow.py", line 89, in async_step_manual
return await self.async_step_validate()
File "/config/custom_components/triones/config_flow.py", line 67, in async_step_validate
error = await self.toggle_light()
File "/config/custom_components/triones/config_flow.py", line 101, in toggle_light
self.triones_instance = TrionesInstance(self.mac)
File "/config/custom_components/triones/triones.py", line 26, in __init__
self._device = BleakClient(self._mac)
File "/usr/src/homeassistant/homeassistant/components/bluetooth/models.py", line 207, in __init__
raise BleakError(f"No device found for address {address_or_ble_device}")
bleak.exc.BleakError: No device found for address 12:18:11:00:F4:39
Is there a chance that my strip is not supported? Thanks!
These are my UUID-s:
00001800-0000-1000-8000-00805f9b34fb
0000ffd5-0000-1000-8000-00805f9b34fb
0000ffd0-0000-1000-8000-00805f9b34fb
Heyyy, it was a bluetooth modem problem, got it fixed!
Hey, I installed the latest version but it doesnât dettect the LED strip and when i manually put in the mac adress it says that is unable to connect to it
Hi guys, anyone knows floodlight with this chip that I can get in UK? thanks
