Custom component: Long Time State Storage (LTSS) utilizing TimescaleDB
@rdnzl
Simple answer: Yes!
Longer answer: Yes, provided that the database has the extensions required by LTSS installed (timescaledb and postgis). I am assuming you are talking about this add-on (Home Assistant Add-on: PostgreSQL + TimescaleDB) in which case both the timescaledb and postgis extensions are provided in the package and hence should work out of the box.
