Custom component: Long Time State Storage (LTSS) utilizing TimescaleDB
Thank you @freol for the quote. that does help me.
I hope it is okay to ask a follow-up question or two:
  • If Recorder is writing both states and events to the DB, then using LTSS will mean that all states are written/stored twice. Once by Recorder and once by LTSS. Correct? LTSS does not disable Recorder?
  • If LTSS does disable Recorder, would this mean that I am losing the events data? And if I wanted to record events, I would have to disable/remove LTSS.
Thank you very very very much for this! It was exactly what I needed. Set up everything yesterday, working like a charm. I did encounter a few things during my setup, it’s not a ltss issue but there are bits and pieces of information everywhere that I needed to gather to get everything up and running resulting in a ton of open browser tabs.
Tried to write down everything I did for the complete setup and published it here, hope it will help
others during the setup.
https://cristian.livadaru.net/home-assistant-grafana/
Cris
as mentioned in the description text latitude and longitude from sensor attributes are stored in the location column. but how can I use them in Grafana? I try to use a device_tracker in a Track Map but it needs latitude and longitude for that… Does anybody have a Grafana example?
found it! In Grafana TrackMap Plugin you need to create two queries, for example for a device_tracker:
SELECT
  $__timeGroupAlias("time",$__interval,previous),
  st_y(Location) as latitude
FROM ltss
WHERE
  $__timeFilter("time")
  AND entity_id = 'device_tracker.XXX'
  AND state NOT IN ('', 'unavailable')
GROUP BY 1,2
ORDER BY 1,2
and
SELECT
  st_x(Location) as longitude
FROM ltss
WHERE
GROUP BY 1,2
ORDER BY 1,2
Interested in this since I currently use MQTT Eventstream → Telegraf (custom build with psql support) → Timescale. I’m missing regular updates for sensors that don’t update that often. Is this something this component can do? That is to write states at least say every 5 mins?
I’ve been using this component for a few months now, and it’s been great, but after adding solar panels to my setup, I’ve noticed some issues with my queries, and I could use some help figuring out the solution.
When the solar panels are online, my power consumption drops to 0, which is recorded once. This stays at zero for long periods of time, meaning no new data is recorded for long periods of time.
When I graph the raw data, no problem (with the right line interpolation).
But when I try to time bucket my data, stuff gets completely out of wack. See below graph, with the raw data (graphed), raw data (points only) and the 5m time bucket, carrying forward where it should drop to 0:
My query:
SELECT
  time_bucket_gapfill('5m', "time") AS "time",
  locf(
    AVG(state_numeric)
  ) AS "Phase 2 5m"
FROM ltss
WHERE
  AND entity_id = 'sensor.power_consumed_phase_2'
GROUP BY time_bucket_gapfill('5m', "time")
ORDER BY 1
Any ideas how I could overcome this issue? This is my first time working with Timescale so I may be missing something obvious, would love any hints.
EDIT: To clarify, it’s hard to tell, but there are raw points at 0 every time.
This is not because of Timescale itself, but simply because of the structure of your data :wink:
It seems the query does exactly what it is supposed to do, which is to calculate the 5 minute average? Grafana then always takes the last value, so long. Until it gets a new value.
You can either try a SQL CTE to prepare your data accordingly, or you test once whether the specification of a value with which Grafana should interpret missing information, already helps. Like this: $__timeGroup(dateColumn,‘5m’, 0)
Thanks for your reply. I’m aware it’s not because of timescale or the ltss component, it’s just that, well, I got stuck on how to actually process the data, heh.
time_bucket_gapfill, as far as I understand (and observe), is supposed to “create” datapoints for Grafana, so there are no gaps for Grafana to fill. It consistently creates datapoints at every $interval, in this case 5m.
This is reflected also by my continuous aggregate tables/materialized views, which reflect the same “wrong” data before hitting Grafana.
I have tried using the $__timeGroup("time",‘5m’, 0), which, interestingly, does something, but I’m not sure what. The resulting query functionally is identical to mine, but adding the macro makes Grafana handle it differently (but not correctly).
Below another graph, with the macro’d query in green, and a terrible hack that results in the correct data in red:
The query I came up with for this, while it does produce the correct data, is obviously extremely hacky and fragile, it first executes the actual query I want with a time_bucket_gapfill of less than the interval my data comes in (more than the interval, even setting it to 2s, completely messes up the data in a similar way to my original issue), as a subquery, then on the “complete” gap-less data it executes the actual time bucket I want:
SELECT time_bucket_gapfill('5m', "time") AS "time",
  locf(
    AVG(state_numeric)
  ) AS "Phase 2 5m awful"
FROM (
  SELECT
    time_bucket_gapfill('0.5s', "time") AS "time",
    locf(
      AVG(state_numeric)
    ) AS state_numeric
  FROM ltss
  WHERE
  GROUP BY time_bucket_gapfill('0.5s', "time")
  ORDER BY 1
) AS t1
WHERE
ORDER BY 1
So in short, the issue is in the query somewhere, my “workaround” in red produces the correct results I want to see, but seems like an incredibly inefficient hack and I imagine there’s a much smarter way to do it.
@SharkWipf
Not sure if this has anything to do with the issue, but can you try to alter your initial query as follows:
SELECT
  time_bucket_gapfill('5m', "time") AS bucket,
  locf(
    AVG(state_numeric)
  ) AS "Phase 2 5m"
FROM ltss
WHERE
GROUP BY bucket
ORDER BY 1
And report back if that changes anything?
No, this component simply listens in on (and writes to timescale) the state change events as produced by HA internally. As such, no “extra” data points are inserted.
You may be interested in functionality such as time_bucket_gapfill and locf in timescale to take care of this during graphing, analysis etc?
Unfortunately no dice. Grafana requires a column called time, so calling it bucket fails it on that, and Postgres/Timescale doesn’t allow grouping by an alias, requires the same complete time_bucket_gapfill() to be in the GROUP BY (db query error: pq: no top level time_bucket_gapfill in group by clause).
So just Name the bucket column “time” instead of “bucket” and use “GROUP BY 1” instead. :wink:
Maybe you can execute the query directly with some DB client instead of Grafana? So that we get a better understanding of the structure of the data output.
That’s essentially my original query again, result is also identical to my original query.
I’ve run this query against psql directly, as well as my raw data query (without bucketing), the former shown below, the latter I’ve uploaded here because of its size: https://clbin.com/W1man
The raw query is just:
SELECT
  "time",
  state_numeric AS "Phase 2 raw"
FROM ltss
WHERE
  "time" BETWEEN '2022-10-08T08:00:05.341Z' AND '2022-10-08T12:07:35.001Z'
ORDER BY 1
@SharkWipf
Hmm, I think you should actually be able to get this done without the locf function. How about this:
SELECT
  COALESCE(
    AVG(state_numeric),
    0.0
  ) AS "Phase 2 5m"
FROM ltss
WHERE
ORDER BY 1
What I learnt from this exercise is that locf is carrying forward the value of the previous time bucket and not actually the value of the last known sensor value. Maybe its just me, but the naming is a bit misleading?
EDIT: You may also want to have a look at this. You are currently calculating the arithmetic mean for every time bucket which may be misleading if the samples are unevenly spaced.
Interestingly, in this version without LOCF and with COALESCE 0.0, the result becomes 1-to-1 identical to the earlier $__timeGroup example with LOCF. Not sure how that works, but unfortunately I still believe that data to not be correct. Here’s another shot of it compared to the raw data and the “awful” but accurate workaround (“freol 2” and “timeGroup” being identical):
Seems like time_weight() might indeed be the solution, unfortunately I do not have a way to test it.
The time weighted average functions are part of a separate Timescale Toolkit extension.
I got this setup running in Docker (well, Podman) on an anemic Pi2B, and unfortunately the current TimescaleDB container image that includes Timescale Toolkit does not support multiarch like the old, deprecated image it was supposed to replace, so I’m stuck on that image.
I’ve opened an issue about this back in May, but unfortunately it does not appear to be a priority for them at this time.
I might see if I can install it manually at some point, but everything on this Pi takes forever and I’m glad I even got this compose stack working, so I’ll probably just have to settle for my “awful” solution I guess.
Thanks for your help, if you have any other solutions I’ll be happy to try, if not, at least my awful workaround should do the job, hopefully without running my Pi out of memory.
EDIT: To clarify, I had changed the bucketing to 1m instead of 5m in this screenshot, for better clarity of the issue. Same issue applies to 5m and other intervals of course.
Yeah I tried playing with gapfill etc with my MQTT Eventstream-setup as well. It doesn’t really work when the last data point is outside of the query time window. It also doesn’t work well with time windows including future times - future energy pricing, prognosis data combined with data from sensors results in faked values until end of graph (maybe there’s functionality for this in TS, haven’t looked in to it because of scenario 1 won’t work anyways).
But OK, just reacting to events, like MQTT Eventstream. Follow up question then: I wonder if I can use a similar workaround with LTSS. What I did was to create an appdaemon app that uses the mqtt publish service to publish sensor values on an interval.
Is there some service or event I could trigger like that to make LTSS log a data point? Perhaps manually triggering a sensor update event could work? But a cleaner trigger would be nicer.
Does anybody have a generic downsampling job for ltss ?
I see a simple one exist for influxDB (InfluxDB 2 data retention - my approach), can we have the same approach for timescaleDB.
Hey, my timescaledb addon for HA works for armv7, aarch64 and amd64.
Could try that one. You could start it as a regular docker image outside of HA.
Sure!
See: Pinned: Additional Documentation for Timescaledb Integration · Issue #1 · Expaso/hassos-addons · GitHub
This creates materialized downsampled views.
The underlying data can then be auto-removed from the ltss hypertable when it’s older then, say 6 months?
SELECT add_retention_policy('ltss', INTERVAL '6 months');
Create a retention policy | Timescale Docs
Hi, i’m using container dekiesel/timescaledb-postgis:1.7.4-pg12 for aprox 2 years now.
I’d like to upgrade to timescale 2.8 + postgresql 14, using this guideline:
https://docs.timescale.com/timescaledb/latest/how-to-guides/upgrades/upgrade-pg/
This guideline tells me to first upgrade to timescale 2.8, and after that upgrade to postgresql 14.
However, i get stuck in the very first step: upgrading to timescale 2.8
ALTER EXTENSION timescaledb UPDATE;
It tells me that i cannot update, since the original docker container uses timescaledb 2.1.0-dev. Upgrading from dev is not supported.
Is there any migration path I can follow?
