Hi, I see some strange behaviour with this version and there are no roller errors logged in the system log about this.
So they just get out of sync and stop moving. And we have to press multiple times on the physical button to fix it.
Normally we have 3 rollers that open via an automation.
But sometimes we open them manually in the morning. The physical buttons are not far away from each other so we press up in room one, up in room 2 and up in room 3.
But most of the time one or 2 of them stop moving after a couple of seconds. No error logged and the state in HA shows they are moving/ opened.
Another thing I noticed is that if an HA automation opens or closes a roller. And we interrupt it via a wall button (all rollers have a 2 button config (open/stop & close/stop). Then it does not work correctly anymore.
You also mention this above:
Anything I can do to better understand what is going on?
Enable debug logging?
Can it be due to the automation? I have one automation that closes 5 rollers when the sun goes down. Sometimes one is still open. Never had this with Nikobus schedules. I already put a 1 second pause between them. But maybe I need to try with 5 seconds or so.
