Hey @pbutterworth any other thoughts on how I could get this working?
Ok, since it is not a lelink, it probably has different BLE UUIDs.
Got any documentation on this unit?
Also, where are you located?
I have a 2020 Leaf (ZE1) and was doing some background reading to get a solution for monitoring the carās charge as live as possible (and triggering climate etc), without using the awful Nissan cloud stuff.
Am I right in thinking that the OBD port is physically shut off when the car is idle, with no way to trigger it at all? I can see some discussion of commands used by the TCU (Nissan Connect) to wake up the system but thereās no real conclusions, and also removing the TCU might be necessary, which apparently stops lots of important parts of the entertainment system working.
I think the only real way to achieve this seems to be splicing into the EV CAN (which runs through the passenger cabin), connecting that to an ESP32 (which does CAN natively) and then reading the data directly off the bus. Hopefully being able to insert commands to control the heating etc? I have some transceivers on order from AliExpress, although I might impatiently buy one from a UK seller to get started sooner⦠It would be nice if it could all be done from ESPHome, but I suspect it might be a bit too complicated.
Yep, thereās no apparent way of āwaking upā the CAN gateway. Not sure about the TCU stuff, as my New Zealand model doesnāt have any of that stuff.
If you are looking to tee into the EV CAN, then you should check out OVMS (https://www.openvehicles.com/). Thereās a few out there who have done some work to splice into the CAN busses on the other side of the gateway. I just could bring myself to pony up the US$250 for the module.
Hiya, yes I read about OVMS ages ago and itās tempting, but indeed seems a bit OTT for what I need to do, although it does have 3x CAN buses and doing more than 2x on the ESP32 means you need an external CAN controller (a bit messy), although I donāt think Iāll need to use more than the EV and CAR CAN, soā¦
I just re-read this thread fully (which you contributed to) and I didnāt spot that you can tap into the buses using 24 pin extension cable - much neater than the other posts I had read about hacking open the installed wiring! Iāll order in one of those cables nowā¦
Hi Paul,
Iām just getting back into this now. Iāve had to change a few slices to suit a 30kWh car but the odometer has me stumped. I can see the correct value in the initial frame but I canāt figure out how to get it.
The frame is 763037F2211FFFFFFFF
The odo is 164,583 which I can get from starting from index 2 to index 5 (37, F2, 21) but instead the system provides 1,114,112.
Any ideas?
Thanks!
Daniel
Looks to me a bit like it is reporting km*50.
763 - header
03 - length
7F2211 - payload
FFFFFFFF - garbage
7F2211 = 8331793
8331793/50 = 166636
Your odo = 164585 (pretty close)
hmm, good guess but I just tried it on our other leaf (24kWh) which has half the number of km and it provided the same 763037F2211FFFFFFFF. Iām picking b"03220e00", isnāt correct for the older cars but unfortunately there is not much online for them.
p.s. ignore finding164583 (above) in 37fe21 - that was ChatGPT hallucinating!
@Arquiteto, would you mind sharing your config? I have a 2016 AZE0 Leaf and similar Vgate iCar Pro BT4.0 dongle. But I havenāt managed to get it to work with this.
The first problem I see to have is getting HA to see the dongle. I have flashed an ESP32 with bluetooth proxy, but I donāt know how to get it to appear in HA.
Then, the tweaks youāve made to Paulās code are likely to be helpful.
Thanks!
Luke
The good news is I was able to get it to work with my 2016 Leaf using the tweaks @Arquiteto posted above, with my Vgate iCar Pro BT4.0 using these UUIDs in elm327.py:
SERVICE_UUID = "000018f0-0000-1000-8000-00805f9b34fb"
CHARACTERISTIC_UUID_READ = "00002af0-0000-1000-8000-00805f9b34fb"
CHARACTERISTIC_UUID_WRITE = "00002af1-0000-1000-8000-00805f9b34fb"
It would be good to expose the UUIDs in the config somewhere so we donāt have to mod the code (I may look into that).
I have the same problem as others with older Leafs with the odometer. I found these to links that reference PID 5C5 = 1477 for the odometer:
https://leaf-obd.readthedocs.io/en/latest/pid/5c5.html
But, Iām unclear how this translates into the code. @pbutterworth any pointers?
Iāve been messing around with my attempt at solving the problem within ESPHome. Iāll probably create a separate thread, but Iāve been able to splice the 24 pin connector behind the instrument panel (into the CAN gateway) and then filter some messages using the CAN bus component. Iām just using the car/vehicle CAN at the moment, some relevant stuff does appear on there, for example I can get the SOC when the car is on or charging. Iāll look at the EV bus in more detail later. I havenāt been able to wake the EV system through the car/vehicle CAN yet, although the car CAN does seem to be active all the time and HA responds instantly to a door being opened etc.
Iāve put some details in this blog post, which Iāll try and update: Notes on integrating a Nissan Leaf ZE1 and Home Assistant
I have one of those dongles, It doesnāt seem to work with LeafPpy pro, so I doubt it will work with this setup either.
hello
can anyone recommend a solution to this problem on last HA 2024.12 ?
Good day. I ask for help from the community. I got a NISSAN LEAF AZE0 2017. Iām trying to install ānissan_leaf_obd_bleā.
OBD 2 scanner - Viecar V1.5 Bluetooth 4.0, has:
(is determined using: https://play.google.com/store/apps/details?id=com.macdom.ble.blescanner&hl)
SERVICE_UUID = "0000fff0-0000-1000-8000-00805f9b34fb"
CHARACTERISTIC_UUID_READ = "0000fff1-0000-1000-8000-00805f9b34fb"
CHARACTERISTIC_UUID_WRITE = "0000fff2-0000-1000-8000-00805f9b34fb"
Made changes to the files elm327.py and bleserial.py
Iām getting an error when i try to install this integration: āno_unconfigured_devicesā
Bluetooth-proxy log:
[10:44:34][V][esp32_ble:348]: (BLE) gap_event_handler - 3
[10:44:34][V][bluetooth_proxy:058]: Proxying raw packet from XX:XX:XX:XX:XX:XX, length 18. RSSI: -71 dB
[10:44:34][V][bluetooth_proxy:061]: Proxying 1 packets
[10:44:34][VV][api.service:345]: send_bluetooth_le_raw_advertisements_response: BluetoothLERawAdvertisementsResponse {
advertisements: BluetoothLERawAdvertisement {
address: 154886500828764
rssi: -71
address_type: 0
data: ' Viecar\xf0\xff
Homeassistant.log : 2025-01-08 16:30:44.956 WARNING (ImportExecutor_0) [homeassistant.core] Config was used from nissan_leaf_obd_ble, this is a deprecated alias which will be removed in HA Core 2025.11. Use homeassistant.core_config.Config instead, please report it to the author of the 'nissan_leaf_obd_ble' custom integration
ā¦the solution is found. In my case, it is necessary to replace the UUID in the manifest.json file
Hello, I too have a NISSAN LEAF AZE0 2017, tried with a Vgate iCar Pro BT4.0, I modified elm37.py, bleserial.py and manifest.json as suggested by the above comments and it works!! thank you all.
Exposing the UUID configurations (also adding the read and white) in the UI would be a big bonus to lot of folks out there.
2025-01-14 17:45:25.608 INFO (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Sending command: b'74303220e01': Total odometer reading (km)
2025-01-14 17:45:25.920 DEBUG (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Received frame: 763037F2211FFFFFFFF
2025-01-14 17:45:25.920 DEBUG (MainThread) [custom_components.nissan_leaf_obd_ble.OBDCommand] Message was shorter than expected (3<6). Padded message: bytearray(b'\x7f"\x11\x00\x00\x00')
2025-01-14 17:45:25.920 INFO (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Sending command: b'74303220e25': Tyre pressure front right
2025-01-14 17:45:26.149 DEBUG (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Received frame: 763037F2211FFFFFFFF
2025-01-14 17:45:26.150 DEBUG (MainThread) [custom_components.nissan_leaf_obd_ble.OBDCommand] Message was shorter than expected (3<4). Padded message: bytearray(b'\x7f"\x11\x00')
2025-01-14 17:45:26.150 INFO (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Sending command: b'74303220e26': Tyre pressure front left
2025-01-14 17:45:26.377 DEBUG (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Received frame: 763037F2211FFFFFFFF
2025-01-14 17:45:26.377 DEBUG (MainThread) [custom_components.nissan_leaf_obd_ble.OBDCommand] Message was shorter than expected (3<4). Padded message: bytearray(b'\x7f"\x11\x00')
2025-01-14 17:45:26.377 INFO (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Sending command: b'74303220e27': Tyre pressure rear right
2025-01-14 17:45:26.669 DEBUG (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Received frame: 763037F2211FFFFFFFF
2025-01-14 17:45:26.669 DEBUG (MainThread) [custom_components.nissan_leaf_obd_ble.OBDCommand] Message was shorter than expected (3<4). Padded message: bytearray(b'\x7f"\x11\x00')
2025-01-14 17:45:26.669 INFO (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Sending command: b'74303220e28': Tyre pressure rear left
2025-01-14 17:45:27.049 DEBUG (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Received frame: 763037F2211FFFFFFFF
2025-01-14 17:45:27.049 DEBUG (MainThread) [custom_components.nissan_leaf_obd_ble.OBDCommand] Message was shorter than expected (3<4). Padded message: bytearray(b'\x7f"\x11\x00')
2025-01-14 17:45:27.050 INFO (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Sending command: b'74303220e24': Remaining range (km)
2025-01-14 17:45:27.296 DEBUG (MainThread) [custom_components.nissan_leaf_obd_ble.obd] Received frame: 763037F2211FFFFFFFF
Do I understand correctly that this data (763037F2211FFFFFFFF) is repeated in all models NISSAN LEAF AZEO?
Good day! On the odometer issue in Nissan Leaf AZEO. Link to an interesting article:
Leaf AZE0
I am not a programmer. Maybe someone will help me implement the odometer measurement?
Pretty sure that is when the TPMS module is not switched on, was the car off at the time?
I am trying to get Odometer data. Odometer data in ZE1 is available in EV-CAN. Odometer data in OZE0 is available in CAR-CAN. TPMS doesnāt work at rest, and I understand that.
