[Custom Component] Roborock communication
for now only integration ok
S6 Maxv is available as a device, not an entity
I don’t know how to proceed now
New HACS integration constantly telling me i have an incorrect username and password. Verified as working within the Roborock app.
Now entity is operative
Do you use the same Login (email address) and password as for the Roborock application?
I try but it gives me every time a connection error message.
I use my email as login, my password and DE server because i come from Belgium.
Any idea ?
same credentials as for the roborock app
It’s also working for me on an S6, however I dont think it’s able to pull the brush/sensor use info.
thanks for all your work! I just added the integration and was able to connect my roborock s6 maxV :+1: In the next days I will make some tests and then I can give you feedback whats working/notworking :slight_smile:
Great work, thanks
I added the vacuum map card (same card as the original integration) and I’m getting the following error on the map:
Invalid calibration, please check your configuration.
Any idea what I’m doing wrong?
Same here, unfortunately. I’ve verified my password and tried both username and email from the Roborock app, it still won’t log in.
Does anyone have an idea how to fix that?
Hello, nice work thanks, I installed it and immediately connected it without any problems, it seems to work, I have to test it for a while, even if for some settings you always have to use the roborock app, if you implement other functions such as washing selection, room management and cleaning scheduling would be top. good job.
I was excited to try the Roborock integration, switched my S5 MaxV back to the Roborock app and configured it in Homeassistant. After some fiddling, I had it as completely configured as with the Xiaomi integration.
However, I discovered one vital feature had stopped working. Pause and resume no longer work. I used the power button on the vacuum (or the pause/resume button in the Lovelace card) to pause and continue cleaning. Now it restarts cleaning instead :confused:
Has anyone else come across this change when switching to the Roborock app?
