I think I know the reason why the command does not work but don’t know how to fix it. The command works for an ONVIF camera. The one that I would like to control is non-ONVIF. I am simply using RTP. I would not have thought the device type would matter as calling the API is effectively updating a config in the database ?? I think it’s a shinobi issue??
Even in the shinobi UI (bottom menu) , changing the mode there does not work for any of my non-onvif cameras. The only to change the mode is in the monitor configuration.
The command is related to Shinobi, not the camera itself, that is weird but will try it over the weekend,
For me it controls all camera with or without onvif,
Regarding the installation, I guess you are working with the master branch, to verify that it is supporting latest api, can you please post a screenshot of the login page (dashboard v2/v3)?
Shinobi crashed the PC after a while and only then that I noticed that CPU was on continuous 100% utilization. Don’t understand why when all I was doing was recording… I have disabled everything else (at least the ones that can be disabled in the UI). I ended up jumping ship to frigate. While there is no GUI for configuration, it’s not as difficult as I thought. I would have preferred a solution with a good configuration UI for other users in the house who don’t understand YAML files.
Hi, sorry for the delay in response other projects took over… you know how it goes!
Here’s the log entries when trying to retrieve the api key:
This error originated from a custom integration.
Logger: custom_components.shinobi.component.api.api
Source: custom_components/shinobi/component/api/api.py:149
Integration: Shinobi Video NVR (documentation, issues)
First occurred: 3 March 2023 at 21:57:18 (27 occurrences)
Last logged: 06:28:38
Failed to post JSON to {base_url}?json=true, HTTP Status: Not Found (404)
Failed to post JSON to {base_url}?json=true, Error: Cannot connect to host 192.168.1.41:80 ssl:False [Connect call failed ('192.168.1.41', 80)], Line: 207
Failed to post JSON to {base_url}?json=true, Error: http://192.168.1.41:80 ?json=true, Line: 207
Failed to post JSON to {base_url}?json=true, Error: http://192.168.1.41:8080 ?json=true, Line: 207
Invalid response while trying to get API keys, Payload: {'ok': False, 'msg': 'Not Authorized'}
It states Invalid credentials but these are exactly what I use to access the platform:
Logger: custom_components.shinobi.config_flow
Source: custom_components/shinobi/config_flow.py:69
First occurred: 3 March 2023 at 21:57:05 (16 occurrences)
Failed to create integration, Error: invalid_admin_credentials
Failed to create integration, Error: missing_permanent_api_key
Failed to create integration, Error: invalid_server_details
The shinobi application is hosted on an ubuntu dedicated server so nothing special here…
Home assistant hosted on a dedicated mini pc… so again nothing special here with the exception of SSL enabled via duckdns add on… not sure if this would have anything to do with it as other apps are fine none https that is.
I’m building a new dedicated Shinobi server (the old one was on docker). If I try to switch the server in the integration it doesn’t show any devices on the new server. Cam settings are identical including JPEG API enabled in camera settings.
Tried deleting the integration, redownload in HACS with no effect.
Switching back to the old shinobi server show the old cams.
Do I need to edit some files in home-assistant?
After a reload of the integration this is in the log
2023-03-28 20:59:23.469 INFO (MainThread) [custom_components.shinobi.core.api.base_api] Performing login
2023-03-28 20:59:23.469 INFO (MainThread) [custom_components.shinobi.component.managers.home_assistant] WS Status changed to Connecting, API Status: Connected
2023-03-28 20:59:23.481 INFO (MainThread) [custom_components.shinobi.component.managers.home_assistant] WS Status changed to Connected, API Status: Connected
2023-03-28 20:59:23.481 INFO (MainThread) [custom_components.shinobi.component.api.websocket] Starting to listen connected
2023-03-28 21:00:08.484 INFO (MainThread) [custom_components.shinobi.component.managers.home_assistant] WS Status changed to NotConnected, API Status: Connected
