I think you’re right that it’s something to do with that calculation not being entirely correct. It is correct most of the time but has small errors constantly (like the spikes in your graph) and seems to have some systemic error during periods of high import.
The question is why these issues didn’t happen when our usage pattern was different (i.e. minimising export).
The figures in the SolarEdge app are equally bizarre. Some days look correct and roughly match what HA tells me, other days the app shows solar production to be way higher (e.g. double), which just can’t be true. I can ask SolarEdge about this but I suspect I won’t get any useful answers.
I think he’s referring to this page: GitHub - binsentsu/home-assistant-solaredge-modbus: Home assistant Component for reading data locally from Solaredge inverter through modbus TCP which mentions that Power Control options are enabled by doing two steps 1. Set Advanced Power Control to Enable and 2. Set Reactive Power mode to RRCR. But I believe that page is only relevant for the original SE Modbus, not the multi one. But I am curious as to whether not following step two could be the reason that my Power Control commands only last a few seconds before they are overridden back to the defaults
This is available in Release v2.4.10-pre.2 along with new button entities for commit power control settings and reset power control settings to defaults.
Thanks for the integration. Due to negative FIT today, I want to curtail any solar exports. On changing the Site Limit to 0 W, the active power limit will reduce to approx what i am consuming. However about 30 secs later the site limit is 5000w and active power 100% so i am paying to export. What am I missing?
Is this your first time controlling your inverter with HA or have you been successful with other commands? I just ask because I have what sounds like the same problem. None of the power control commands I give “stick”. They are always canceled within 10 seconds or so. I’ve been told it’s because my inverter is enrolled in a VPP and therefore all my commands will be overridden by SolarEdge’s “central control” since only the VPP has permission to change things. Apparently if I unenrol, SE will allow me to control it.
Thanks Kingston for taking the time to respond. It makes sense as I’m wondering if I have been enrolled in their similar vpp product which I didn’t think i was entitled to.
When I have a negative tariff I set Active Power Limit “number.solaredge_i1_active_power_limit” to 0 (zero) myself. When the tariff is negative I don’t want any solar production to use in the house too; all has to come from the grid since the tariff is negative.
I’am trying to activate power control, I have set reactive power mode on RRCR but I can’t find the option advanced power control, so can’t enable is, can some Help me trough the menu where I can find it?
This I have set now but power limit is unknown within ha:
In Home Assistant turn on the “Grid Control” switch for the inverter device (it’s getting renamed to Advanced Power Control in the latest pre-release).
Also I’ve added the Reactive Power Mode setting to the integration in the latest pre-release.
Ok, i will look into it now i’m using the modbus tcp component.
But this topic was the only topic that had information about power control so i had hoped somebody knew wat setting i had to activate in the set app
for a few weeks I have major issues with Home Assistant becoming unresponsive for several seconds. Sometimes this happens every few minutes, sometimes only once an hour, sometimes only once every few hours. During this time, my automations don’t run propery (e.g. motion detectors), so it’s really annoying.
After searching for quite some time, it seems that the SolarEdge Multi Modbus integration is the cause of these issues. Everytime HA becomes unresponsive, the SolarEdge entites become unavailable. You can see that in the log of the SolarEdge integration.
I use the integration for almost a year now and it worked properly for a long time. I don’t know what changed, but I need to find a solution.
HA is running as a VM on Synology DS918+. SolarEdge Inverter has a fixed IP. And I’m using the ModBus-Proxy Add-On in Home Assistant, because I also need to connect to the SolarEdge-Inverter with EVCC. So ModBus-Proxy connects to the SolarEdge Inverter and HA to the Proxy.
I turned on full debug and wait for the issue to happen again. But the last hour everything was ok.
So the bad news is that you have a lot of other custom components, and if you think it’s my integration that’s causing the problem then you will need to remove them and run just solaredge-modbus-multi to isolate it as the cause.
Entities going unavailable is what it’s supposed to do if it loses communication with the inverter and all the retry attempts also fail. The integration does not hold onto stale data past the polling interval plus retry intervals. However, if it’s triggering unavailable state then that means it’s running through all the steps to get there, not locked up. This could be any networking problem, hardware problem, or other integration sync blocking the main thread of Home Assistant. So unavailable state alone doesn’t indicate an integration problem.
You can turn on full debugging and see if you can spot what’s holding up the main thread:
Thank you! I put this in the configuration.yaml and wait for the issue to happen again. I don’t say for sure that your integration is the issue. I hope it’s something else, because your integration is one of the most important ones in my setup.
I will report back as soon as I have the log files.
Now EVERY integration has “debug protocolling active”. I just hope the issue reappears soon, because the home-assistant.log rapidly grows…
