I fixed the laggish lovelace ui by adding a small sleep to the loop. Had that initially but removed it, apparently it was needed for some hardware/installations.
Regarding the utility meter and storing the previous value that should be possible to fix. I’ll see when I get the time to dig into that issue. Can you please create an issue at GitHub for it? Thanks
