Thanks for replying. Via samba I can see that inside custom_components the folder is correctly named solaredge_modbus. Strangely though, if I go to my HACS page inside HA I cannot see the integration as installed. If I search it by adding new repository I get an installation button. How can it be?
I’m not getting any data into HA, however I’ve had this configured for another automation system for quite some time without issues. Currently using with the C-Bus SHAC.
Ok, I must be stupid. I installed the integration through HACS, it asked me to restart HA.
After restart is shows the integration in HACS integrations, the folder custom_components also shows the “solaredge_modbus” directory with files.
But what then? I cannot add the modbus integration in the “regular” Integrations page cause it’s not listed. I’m on core-2021.11.3
Solaredge only handles one modbus client at a time, so if you want to use this component side by side with another one using modbus tcp you have to setup a modbus tcp proxy
This component does not have an integration/UI for setup, maybe you are using another one that’s out there? This one requires a manual config in the configuration.xml file.
That’s what I suspected, even when I shut down the original connection I wasn’t able to connect. Perhaps I’ll restart the inverter to check as this may also be the reason I can’t talk to it with another client.
Is there a modbus proxy available for HA, wasn’t able to find anything so far. That’d be a good thing to have.
EDIT: Actually, it just occurred to me, would using the nginx proxy manager do what I need, it is just providing a connection after all.
I did find this one after poking around, would it be possible to install this into HA?
When installing through HACS i left de default “scan interval” on 30 seconds. If I want to change it to, for example 5 seconds. Do I need to remove and add the integration again? And what is considered a good value? Resource wise I’m using a Odroid N2+ for HA.
Thanks for sharing. I followed these steps, but it didn’t work for me at all. I almost gave up, but luckily I decided to connect an ethernet cable as it was connected through wifi and it worked right away. So my advice is, try the ethernet cable before you waste your time trying to get the details through wifi.
my inverter has CPU ver. 2.0x (soleredge 8k), and does not have SD card slot, its just empty space in PCB. In communication settings theres no modbus tcp, only rs485, how can i solve this?
Solar curtailment, how to know that it’s happening in realtime ?
Hey people, does anyone know much about the ‘solar curtailment’ subject in relation to the data we get out of our SolarEdge inverters with this integration ?
I’d like to know when the grid operator is curtailing my grid feed if we have a way to do it.
I admit I really don’t know much about the subject, other that what was in the ABC news article online, and I have not been able to find out if there is a particular grid voltage above where our SolarEdge inverters stop feeding in…
Cheers.
Hello
On initial setup of modbus solaredge I change the port to 502 and leave scan interval at 30, now I cannot find these settings anymore, I want to change the scan intervall to 5 seconds.
please help.
