### The problem
When adding a Tapo C320WS to HA via ONVIF integration or Tapo c…ustom component, which uses ONVIF for motion detection, the motion detection binary sensor does not appear. A Tapo C110 works flawlessly.
### What version of Home Assistant Core has the issue?
core-2023.1.1
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant Container
### Integration causing the issue
ONVIF
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/onvif/
### Diagnostics information
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
Logger: custom_components.tapo_control
Source: components/onvif/event.py:82
Integration: Tapo: Kamerasteuerung (documentation, issues)
First occurred: 13. Januar 2023 um 14:56:20 (2520 occurrences)
Last logged: 10:03:48
Unexpected error fetching Tapo resource status data: illegal status line: bytearray(b'POST /onvif/service\x00HTTP/1.1\x00\x00Host\x00 192.168.20.108:2020\x00\x00Accept\x00 /\x00\x00Accept-Encoding\x00 gzip, deflate, br\x00\x00Connection\x00 keep-alive\x00\x00User-Agent\x00 ZHTTP/1.1 500 Internal Server Error')
Unexpected error fetching Tapo resource status data: All connection attempts failed
File "/usr/local/lib/python3.10/site-packages/httpcore/_exceptions.py", line 10, in map_exceptions
yield
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 188, in _receive_event
event = self._h11_state.next_event()
File "/usr/local/lib/python3.10/site-packages/h11/_connection.py", line 487, in next_event
exc._reraise_as_remote_protocol_error()
File "/usr/local/lib/python3.10/site-packages/h11/_util.py", line 77, in _reraise_as_remote_protocol_error
raise self
File "/usr/local/lib/python3.10/site-packages/h11/_connection.py", line 469, in next_event
event = self._extract_next_receive_event()
File "/usr/local/lib/python3.10/site-packages/h11/_connection.py", line 411, in _extract_next_receive_event
event = self._reader(self._receive_buffer)
File "/usr/local/lib/python3.10/site-packages/h11/_readers.py", line 104, in maybe_read_from_SEND_RESPONSE_server
matches = validate(status_line_re, lines[0], "illegal status line: {!r}", lines[0])
File "/usr/local/lib/python3.10/site-packages/h11/_util.py", line 91, in validate
raise LocalProtocolError(msg)
h11._util.RemoteProtocolError: illegal status line: bytearray(b'POST /onvif/service\x00HTTP/1.1\x00\x00Host\x00 192.168.20.108:2020\x00\x00Accept\x00 /\x00\x00Accept-Encoding\x00 gzip, deflate, br\x00\x00Connection\x00 keep-alive\x00\x00User-Agent\x00 ZHTTP/1.1 500 Internal Server Error')
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 60, in map_httpcore_exceptions
yield
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 353, in handle_async_request
resp = await self._pool.handle_async_request(req)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 253, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 237, in handle_async_request
response = await connection.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py", line 90, in handle_async_request
return await self._connection.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 112, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 91, in handle_async_request
) = await self._receive_response_headers(**kwargs)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 155, in _receive_response_headers
event = await self._receive_event(timeout=timeout)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 187, in _receive_event
with map_exceptions({h11.RemoteProtocolError: RemoteProtocolError}):
File "/usr/local/lib/python3.10/contextlib.py", line 153, in exit
self.gen.throw(typ, value, traceback)
File "/usr/local/lib/python3.10/site-packages/httpcore/_exceptions.py", line 14, in map_exceptions
raise to_exc(exc)
httpcore.RemoteProtocolError: illegal status line: bytearray(b'POST /onvif/service\x00HTTP/1.1\x00\x00Host\x00 192.168.20.108:2020\x00\x00Accept\x00 /\x00\x00Accept-Encoding\x00 gzip, deflate, br\x00\x00Connection\x00 keep-alive\x00\x00User-Agent\x00 ZHTTP/1.1 500 Internal Server Error')
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 225, in _async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 181, in _async_update_data
return await self.update_method()
File "/config/custom_components/tapo_control/init.py", line 210, in async_update_data
await setupOnvif(hass, entry)
File "/config/custom_components/tapo_control/utils.py", line 431, in setupOnvif
hass.data[DOMAIN][entry.entry_id]["eventsSetup"] = await setupEvents(
File "/config/custom_components/tapo_control/utils.py", line 441, in setupEvents
if await events.async_start():
File "/usr/src/homeassistant/homeassistant/components/onvif/event.py", line 82, in async_start
if await self.device.create_pullpoint_subscription():
File "/usr/local/lib/python3.10/site-packages/onvif/client.py", line 311, in create_pullpoint_subscription
pullpoint = await events.CreatePullPointSubscription()
File "/usr/local/lib/python3.10/site-packages/zeep/proxy.py", line 64, in call
return await self._proxy._binding.send_async(
File "/usr/local/lib/python3.10/site-packages/zeep/wsdl/bindings/soap.py", line 156, in send_async
response = await client.transport.post_xml(
File "/usr/local/lib/python3.10/site-packages/zeep/transports.py", line 235, in post_xml
response = await self.post(address, message, headers)
File "/usr/local/lib/python3.10/site-packages/zeep/transports.py", line 220, in post
response = await self.client.post(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1848, in post
return await self.request(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1533, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1620, in send
response = await self._send_handling_auth(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1648, in _send_handling_auth
response = await self._send_handling_redirects(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1685, in _send_handling_redirects
response = await self._send_single_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1722, in _send_single_request
response = await transport.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 352, in handle_async_request
with map_httpcore_exceptions():
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 77, in map_httpcore_exceptions
raise mapped_exc(message) from exc
httpx.RemoteProtocolError: illegal status line: bytearray(b'POST /onvif/service\x00HTTP/1.1\x00\x00Host\x00 192.168.20.108:2020\x00\x00Accept\x00 /\x00\x00Accept-Encoding\x00 gzip, deflate, br\x00\x00Connection\x00 keep-alive\x00\x00User-Agent\x00 ZHTTP/1.1 500 Internal Server Error')
### Additional information
_No response_
